Add Memory
it depends, you will want to check the type of memory first, and make sure you are purchasing the correct type. Also, if you have memory slots that are different colors, you will want to put the memory in two similar colors. also, i would advise buying a set of 2 1gb sticks of ram that are dual-channel capable, and removing the old memory. Otherwise the old stick of memory will significantly slow down the speed the new stick can run at. Memory is extremely cheap at newegg.com, you can get 2gb ddr2 ram for under $30.
