Cameras Logo
Anonymous Posted on Sep 09, 2008
The lcd screen is just showing half black and half white theres no picture but when i plug it into the av socket on tv it shows normal but not on the lcd screen
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
125
Points
It was still under warrenty so i contacted the manufacturer and they are gonna sorted thanks
I have a problem with my samsung lcd it shows me black and white screen i try to set it with manual shows component -pc instead of av -tv
Looks like you need to reread the manual & properly connect. you are plugged into the PC & not the AV input & this is most likely your issue.
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
2helpful
Half of the screen goes black, white, gray and blue lines while the other half still showing tv program
hi,
There can be two possibility for this problem. Lcd driver or the lcd itself faulty. In most cases the lcd driver will become faulty. I have added a picture bellow. There is a circuit board inside your tv like this Covered by a metal cover. Remove the metal cover. You will see there will connection on three sockets. of which 2 will go to the lcd panel and one will go to the mother board. Before replacing that board carefully remove the wires from the sockets and then reconnect the same. some time improper contact can cause this problem.After that check the tv. If then also the problem remains you have to replace that circuit board as whole.
ok
Wii does not show up on the tv screen
This problem is likely due to a problem with your AV cable. Try the steps below to get your Wii up and running.
  • Make sure the Wii is turned on and all cables are plugged in.
  • Unplug the AV cable from the T.V. (The AV cable has a red plug, a yellow plug, and a white plug.)
  • Plug the AV cable back into the television making sure that the red plug goes into the red socket, the yellow plug goes into the yellow socket, and the white plug goes into the white socket.
If problems continue try replacing your AV cable with a new one.
White screen and black vertical lines over half of la26b450 model tv screen
Good day!
that problem is on the cable please try to play dvd or recorded tv shows.
if you play dvd or recorded shows and picture is normal
try to check the connection of your cable and try to touch the connector and move it gently then see the picture of your TV if there's changes
thank you
2helpful
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports...
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
7helpful
4answers
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
