20 Most Recent LG 32LC2R 32 in. HD-Ready LCD Television Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
LG 32LC2R 32 in.... | Answered on May 17, 2016
call a tv repair shop and ask what it will cost for an estimate to repair . so do it free if you have them fix it .if cost is higher than a new set then you decide which way to go .
LG 32LC2R 32 in.... | Answered on Nov 21, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
LG 32LC2R 32 in.... | Answered on Jul 19, 2015
Seems like you have an Inverter issue
Inverter board is under the psu to the left and its job is to
light the lcd panel so you can see the picture
give me more info and i might help you to fix this
LG 32LC2R 32 in.... | Answered on Aug 18, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
LG 32LC2R 32 in.... | Answered on Aug 17, 2014
look for bad caps in power supply.
LG 32LC2R 32 in.... | Answered on Apr 27, 2014
Maybe Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
LG 32LC2R 32 in.... | Answered on Apr 17, 2014
Service menu with LG differs to set to set. If you wish to get more details, check the site linked here. It has service mode options entry and adjust procedure to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
LG 32LC2R 32 in.... | Answered on Jul 15, 2013
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
LG 32LC2R 32 in.... | Answered on Feb 13, 2013
hi, if your tv has totally black screen the cause is either the inverter board get busted or the back light need replacement. if their is a white screen display but no picture, you must check the t-con board for screen panel display which have defective or burnt component parts .
LG 32LC2R 32 in.... | Answered on Aug 11, 2012
That sound a lot like a backlight issue that in a lot of cases is due to poor capacitors on the power supply. The power supply also usually contains the high voltage generators that supply the backlight to the display. Search for that symptom on the internet with your model and brand in the search bar and you will find that a lot of people have the same problem. Those people that are technical often fix it by removing the supply and replacing the capacitors with those from DigiKey or Mouser Electronics. These new parts are not the very low grade Chinese parts that were made to a build the part. I have repaired many computer displays in the very same way- in fact the hardest part of the job is figuring out how to open it up. The capacitors I speak of are the larger Electrolytic types that are showing a puffed condition or are venting. See this answer as it has pictures.
http://www.fixya.com/support/t8813525-turned_set_indicator
If all the other inputs are working and there are no issues in the signal strength and quality , the fault of the failure of the HDMI can be related to an interface within the TV.
This can be related to a logic gate failure and ONLY a logic test will prove the failed section that connected with the processor.
LG 32LC2R 32 in.... | Answered on Oct 25, 2011
The tv power supply board it is shorted and dead.That the board where the tv power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
LG 32LC2R 32 in.... | Answered on Sep 23, 2011
HI EMMANUEL,
FIRST PICK VIDEO 1 FOR THE VCR....YELLOW...RIGHT...WHITE...
THEN RECONTACT ME..
KEN
LG 32LC2R 32 in.... | Answered on Jun 08, 2011
LG 32LC2R 32 in. HD-Ready LCD Television Logo
57 questions posted
Ekse
View Most Popular
  • LG Televison & Video
Most Popular Question
lg 32lc2r hdmi connection acting up lot
  • Televison & Video
