PS3 will play in black/white using av composite cable pluged into L(white) and R(red) ports. The TV will not show a picture with the yellow plug pluged into the video(yellow) port. If I plug the yellow plug into the Y port (not sure of color, maybe green) the picture will show in black and white.
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
SOURCE: i just reconnected my haier television to the
U are using a AV RCA cable for the connections?Ur AV RCA cable connections all matches up like RED to RED,YELLOW to YELLOW and WHITE TO WHITE?Tried another AV RCA cable?Might even tries a HDMI cable for the connections?U tried all these still getting the same result no colors,just black and white.Than ur Tuner board is defective,must be replaced to solved this problems.
SOURCE: I cant get my HLTD7 to output tv via the av-out
I have exactly the same problem with my Haier L32C300 tv. I can't get it to output an audio signal to the stereo. It worked fine on my last tv which was a Panasonic.
My haier plasma monitor blinkred and than blue light..when you put the power it clicks frist 2 times and than 1 more time.please help.
