Hi E1 is a leakage error in your dishwasher; it is usually
displayed either due to a clogged drain or due to water leakage in hose
connections. If the drain pump assembly is not clogged then check the motor
water seal leakage of sump assembly and also check the impeller of washing
pump, if it is worn then replace the impeller. You can also make sure that the
height of drain hose is not over 20". Hope this helps...please post back for
further assistance. Daniel
