Hi. I was able to find a manual for your remote that has instructions on how to program it. Basically, you need to look up the code for your Sanyo device, and enter it in to the remote for the commands to load up.
The manual for your remote is at:
http://mscustomercare.com/forms/JumboRemoteEM_InstructionManual.pdf
Below is the instructions from the manual on how to enter the codes.
Regards,
D
Unfortunately, there is no way to program your universal remote without the code. However, you will notice that there are several "Sanyo" codes listed in the manual that I just provided. You should not need to take any information from the device itself.
Sanyo codes:
004
013
049
108
110
180
209
You may need to try these all out before you find the one that works with your particular model. If you have any more difficulty, please read through the manual that I provided at the link in my initial response. The manual more than likely will answer all of your questions.
Again, the manual can be viewed at :
http://mscustomercare.com/forms/JumboRem...
I hope this helps.
D
P.S- If you are able to get your remote working, please do not forget to "Accept" my solution. Thank you for using FixYa and have a nice day.
I have no manual for the Sanyo nor can I remove it from cabinet to get any numbers
