Toshiba Satellite P105-S6104 Notebook Logo
Posted on Aug 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have NB305 N310 and crashed recently. When I used Toshiba Recovery tool to reinstall OS, it shew Error: 040000058D. Is it a hard drive problem or something else? Your help will be highly appreciated.
Curtis Sewell
Level 3:
  • Master 7,482 Answers
  • Posted on Aug 17, 2011
Curtis Sewell
Master
Level 3:
Answers
7482
Questions
Helped
1943152
Points
24946
Hi 196196...
From what I can find on your error number 040000058D it is that your hard drive is physically damaged...It will probably have to be replaced and then run the recovery tool and it should install normally.
Please take time to rate me
Toshiba tablet R15-S829 has only c drive .can i do partition in this hard drive. is it accptable for this laptop or not.please help
I think the problem is only that your system crashed. So you can try some data recovery software to recover the wanted data from system partition and then reinstall OS,
I suggest you can use a free data backup software to create a recover disc once you enconter such a problem you can recover your data and system easily.
Freeware AOMEI Data Backuper: http://www.aomeitech.com/aomei-data-backuper.html
3helpful
6answers
Mac OS X Computer crashed: how to restore from storejet 25P
Hard drive recovery software is the exact answer for your question how to restore crashed hard drive Mac data. Some days back, due to software conflicts my Mac hard drive was crashed and I was unable to access my data stored in it. I was really tensed because the stored data was very much important to me. Then I searched over the internet and found this software which successfully restored all my lost data and I was very much happy after getting back my data. The software can be downloaded either from official website or by simply clicking here.
Good luck,
Fiona Dsouza
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
2helpful
Error : 10-FC12-0002 comes up during Toshiba system rocovery what does it mean and how do i fix it?
I download this from the Toshiba support site:
While running a full system recovery from the Recovery Media, the installation may fail -- and display one of the error messages listed below. Possible causes of these error conditions are listed at right. Use this list as a troubleshooting guide -- not as an absolute list of causes, as there may be others.
"An error has occurred. ERROR :10-FC10-1710" -- may be caused by a faulty hard drive.
"An error has occurred. ERROR :10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
"An error has occurred. ERROR :10-FC12-045D / 10-FC11-045D" -- may be caused by a faulty hard drive. *****
"An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
"An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
*for this error 10-FC12-045D u nid to call 1-800-457-7777 toshiba advance technical support they will send it to depot or they will recommend ASP (Authorized Service Partner)
I suppose your recovery disks could be bad. You can get another set from Toshiba. I'm also concerned about the health of the hard drive. Did you need to run recovery because the system crashed, because it may not have been an operating sysem crash but rather a hard drive crash. Have the harddrive or whole laptop checked by a reoutable repair person or check my website: www.micromendllc.com
1helpful
Crashed error 03-FFFF-OOOO
if that error occurs while attempting the recovery, typically it indicates a read write error on the hard drive. replace the hard drive and see if the recovery finishes.
(although i have only seen this problem with failing hard drives)
I have a Dell inspiron 531s desktop computer w/ a disc read error
Disc Read error indicated a failing hard drive. Replace the drive will be the fix, then reinstall Windows
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
