LG Electronic Window Air Conditioner Logo
Posted on Aug 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My LG air conditioner is spitting out water and making a weird noise....i took off the front panel and theres a lot of water in what i guess is a condensation pan....ive tried drying the little bit i can get to from the front but after a few minutes it happens again....Thanks for the help
Anonymous
Level 3:
President:
  • Master 1,654 Answers
  • Posted on Aug 15, 2011
Anonymous
Master
Level 3:
President:
Answers
1654
Questions
0
Helped
598175
Points
5047
Go around the back side and unplug the drain hole! These are designed to drain out the back through a hole in the drain pan. Maybe your unit is tipping forward and not draining like it should. You can use a coat hanger or wire or even a shop vac to remove debris from the drain.
Making a noise and spitting water inside
your ac unit may not be installed properly, it needs a 1/4 inch tilt to allow water to drain properly outside. Also make sure your drain plug is open to allow the water to drain out.
My goldstar window air conditioner keeps spitting water out of the vents and making a loud noise, what is it? Please.
Hello
Could be the drain hole is clogged up outside.
Its usually located on the bottom r h side.Needs to be unclogged.Use a thin piece of wire or compressed air or even a good blast of water to fix it.
1helpful
It collect in the front of the unit. I put a small
the unit needs to tilt back a little so the condensation can drain also remove front cover and check drain pan is clear of debris so the water can flow back and out of drain
3helpful
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
It's two years old, and is now spitting out lots of water.
Should have a drain on the unit. Check for ports that have debris in them on the outside of the unit. Clean the debris out and the unit should drain normally.
Started making a noise, spitting water from vent
there is a drain on the pan under the cooling coil - your "blades" if you are looking in from the front cover - the opening could be stopped up going to the back of the unit - you will have to pull it out of shell to see drain line
1helpful
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Troubleshooting
first I would check your air conditioner to see if it is tilted backwards it should drain to the back (outside) . also check to see if the evaporator tray is clear of debris. if it is pluged up water may back up.. let me know and if this don't help we can go deeper..Thanks
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
