2. Press and hold the button on the remote you want to program.
3. Enter the code from the code list.
4 Release button, and then press ONeOFF to see if the component responds to the remote commands. If it doesn't, try pressing the component button and then ONeOFF again.
5. If you get no response, repeat these steps using the next code listed for your brand, until the component responds to the remote commands.
If none of the codes work then try a code search. Instructions below.
The following instructions can be used to program the remote to control each of the devices connected to your TV. If you want to exit the automatic code search without programming any of your devices, press and hold CLEAR until the LED turns off. I. Turn on the device you want to control (VCR, SAT, etc.)
2. Press and hold the button you want to program (VCRI, VCR2, etc.) While hold'Ing the device button, press and hold ONeOFF until the red light on the remote turns on, then release both buttons.
3. Press and release PLAY, then wait 5 seconds or until the LED stops flashing. At this point the remote is searching for the correct code to program. If, after 5 seconds, the device you want to control does not turn off, press PLAY again to tell the remote to search the next set of codes. Continue pressing PLAY until the device turns off or you have searched through all of the codes. There are 20 total sets of codes. If the device does not turn off after pressing PLAY 20 times, then the remote cannot control that particular device. If the device you want to control does turn off:
I . Press and release REVERSE, then wait 2 seconds. Repeat this step until the device turns back ON. 2. To finish, press and hold STOP until the red light on the remote turns off.
@font-face {
font-family: "Cambria";
}p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all
the codes listed for your brand, try searching for your code. The Search Method
allows you to find the code for your device by scanning through all the codes
contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are
working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong
code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
I was here originally with a problem identical to one posted and found that the best solution posted was only partially working. My husband and I were able to get the tv on but that was the extent of it. Once on the remote was not working. Out of frustration we figured out the that if you practice the exact steps after the tv is turned on, 1 hold the set button untill the red light comes on 2 press what you want to set (tv,vcr,dvd,ect.) 3 press power botton aim at unit and wait until it turns OFF then quickly press ent. This did it for us and we are now happily watching tv again without having to toss our beloved giant remote into the garbage. Hope this helps!!!!
u must press and hold the botton titled as code search until the red light is lit. Once you do so, you program in one of the 3-4 digit codes. I am actually dealing with the same delema. I have an Orion tv except i have no clue what the code for it is. If you could help me out with the code that would be great
