20 Most Recent M-Audio StudioPro 4 Main / Stereo Speaker Questions & Answers
Just hooked up my ashton home theater system up
You got scammed by the guys in a Van with a "Good Deal" LOL
http://www.scamshield.com/Feature.asp?id=1
http://www.ripoffreport.com/reports/0/404/RipOff0404098.htm
11/20/2013 7:46:56 PM • M-Audio... • Answered on Nov 20, 2013
M-Audio StudioPhile DX4 4'' Woofer
The "voice coil" inside the woofer must be rubbing against the "yolk" plate. Meaning = it is mechanically blown(damaged) to a point but electrically intact.
My sugesstion is to take out the damaged woofer and "google" for a mew woofer with the correct impendance and size and mounting holes. If you dont know thw impendance, then you should go with at least 8 ohms. More ohms = less risk of overloading the amp. whick can cause a fire!
Good Luck!!
6/11/2009 3:00:59 AM • M-Audio... • Answered on Jun 11, 2009
Buzzing
bad amplifier or input has bad ground conection or positive conection
can you describe if its only one side or comming out both?
10/16/2008 7:07:15 AM • M-Audio... • Answered on Oct 16, 2008
Stopped working
Sorry I don't have a solution, but the speakers have done the same with us. Power comes on, some sound like the wire shorting out, but otherwise no sound. Tried different connection wires, different computers (mac and pc) but no go on any of them. So, I also don't think it has anything to do with you deleting some files.
9/18/2008 9:10:05 PM • M-Audio... • Answered on Sep 18, 2008
No Power
Is there fuse on these monitors?
1/28/2008 11:48:05 PM • M-Audio... • Answered on Jan 28, 2008
2answers
I have found the problem on my M-Audio BX5a monitor is also a 25V 6800uf power filter capacitor problem, only mine popped like a party popper---the other one is okay. The question I have is that it i
If you are sure of what you are doing then replace the capacitor and any other capacitors with a blown/distorted top.These capacitors are polarised capacitors and must be inserted/soldered correctly in place. The stripe on the capacitor is the negative lead.
8/21/2014 12:19:59 AM • M-Audio Audio... • Answered on Aug 21, 2014
Hey.. I just bought a Bx8 studiophille.. Unfortunately I got cheated.. One of the speakers tweeter is not working.. Can you give me a solution.. Where can I get it replace??
How sure are you that't you tweeter and not a contact cable or, sunce they use cheap xhinese capacitors on the m-audio, just a capacitor has dead. Don't buy a tweeter, since they very often die and check the inputs , especially TRS amd rca and unscrew the the backplate and you'll notice that the cables and connectors used are cheapio. So it worth to check the pcb,s if you see broken caps. Which wouldn't surprise me , since their cheap once. And before buy another tweeter, first try it out on another small amplifier, to see if it works. Buying a new ine is the last fase, they ask high prices for a 10 dollar unit. Where did you buy it and how old is the unit? Greetings richard
8/21/2014 12:03:23 AM • M-Audio Audio... • Answered on Aug 21, 2014
Bass Guitar Won't Register
The mics I have seen don't have a filter... but a lot of mixers do have a 100Hz mic input filter. Check the other equipment that you are using also.
4/27/2014 6:22:37 AM • M-Audio Audio... • Answered on Apr 27, 2014
Audio bx5a tweeter
Tweeter just may need to be replaced. Is all the sound coming only from the woofer?
4/17/2014 6:38:01 AM • M-Audio Audio... • Answered on Apr 17, 2014
0answers
Loud rattling noise
hey shawn, try lowering the volumne level & see how the speakers react. www.tiger direct.com has new computer speakers,all different prices & different quality levels. from the best to the cheapest computer speakers.they carry all computer parts. 2 tb hard drives, $89.00for usb2 & usb 3 ports.
10/13/2013 1:46:51 AM • M-Audio Audio... • Answered on Oct 13, 2013
0answers
Change fuse
Be the first to answer 9/16/2013 7:34:59 AM • M-Audio Audio... • Posted on Sep 16, 2013Be the first to answer
M-Audio StudioPro 4 Main / Stereo Speaker Logo
9 questions posted
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Audio Players & Recorders
Most Popular Question
m audio studiophile dx4 4 woofer
  • Audio Players & Recorders
