I disconnected the power cord and opened the back and pulled out the guts and one of the 25V 6800uf power filter capacitors was blown like a party popper---there was debris all over and the cap with the X on it was laying inside. Should I replace both power filter capacitors at the same time, and what are the steps since both are glued to the board; what should I be careful of? Or is this best left to an electronics wiz? Also, the wires to the tweeter were disconnected---one contact is copper the other is silver; one connector has a red mark on it---I am assuming that's for the copper contact and the other for the silver?
And pls put in better ones then the chinese which they put standard in it, you have to replace them both sunce the ither cap is a cheap one and won\'t be top either. Just look for the same capacitance and put in 10 voltage higher once, but one problem: cheap caps are allways small, and fitting them can be a problem , or is just a problem but i should go for nichicon muse or elna simic, since they are good once and not very width .the glue melts when heating it
If you are sure of what you are doing then replace the capacitor and any other capacitors with a blown/distorted top.
These capacitors are polarised capacitors and must be inserted/soldered correctly in place. The stripe on the capacitor is the negative lead.
