20 Most Recent Yamaha Wave Runner Iii Vxr Blaster Pro Raider Gp 700 650 Flywheel Cover Questions & Answers
1994 yamaha
Assuming here that you mean the battery will not hold a charge. When this happens, the battery needs to be replaced.
7/28/2014 1:23:12 PM • Yamaha Wave... • Answered on Jul 28, 2014
I have a Yamaha Ef2600 fw generator that starts and produces voltage and current but also gives out a 'clunking' noise on a 2 - 4 second cycle. What is wrong with it?
Based on the search results there are a explanations, for the clunking noise in your Yamaha EF2600FW generator; 1. Load handling; One potential reason could be that the generator is facing difficulties in managing the load, which could be due to fuel or air supply. This can result in the generator producing a clunking noise. 2. Fuel shortage; Another possible cause might be a lack of fuel supply to the generator leading to a knocking sound. It is advisable to address this fuel issue before operating the generator to prevent any damage. 3. Storage conditions; The clunking noise could also arise from storage conditions. Over time certain components like piston slap or dry rod bearings may develop problems resulting in sounds when the generator is running. To diagnose and resolve the problem with your generator it is recommended that you take the steps; Check and ensure a fuel supply. If needed, clean or replace the carburetor. Inspect the generator thoroughly for any signs of damage or wear in areas like piston and rod bearings. These actions should help. Rectify any issues causing the clunking noise, in your Yamaha EF2600FW generator. If the problem continues you might need to reach out to a technician or get in touch, with Yamaha customer support for help. Always prioritize safety when dealing with generators or any other equipment. If you feel uncertain or uncomfortable about troubleshooting or making repairs yourself it's best to seek assistance, from a professional.
8/25/2023 9:54:21 PM • Yamaha... • Answered on Aug 25, 2023
No power generation
The reasons of no power generation: 1. The voltmeter of the control panel is damaged or the wiring is in poor contact. This situation is generally after the diesel generator starts normally, and the voltage on the meter sometimes does not move. It is necessary to use a multimeter to measure the U, V, W, N phases of the motor, and the phases between U, V, and W. The voltage is about 400v, and the voltage between single-phase U, V, W and N is about 230v. 2. The air switch on the electric ball in the diesel generator is damaged: the phenomenon that occurs is that the diesel generator is normal when it is started, and it trips when the load is turned on. 3. Brushed motor equipped with diesel generator: The disadvantage of brushed motor is that demagnetization occurs occasionally, so it is necessary to keep 1-2 pairs of carbon brushes to prevent this situation. 4. The starting elements are not reached: the starting elements of diesel generators refer to the speed of 1500 rpm, frequency of 50HZ, and voltage of 400v. Many users feel that the noise of diesel generators will be very large when this data value is reached, so they reduce the speed by themselves. , the consequence is that the voltage is not enough, the frequency is not enough, and the power is not generated. After a long time, the power of the diesel generator will be insufficient. 5. Damage to the voltage regulating plate: The function of the voltage regulating plate is to adjust the excitation current correspondingly according to the change of the generator load, so as to maintain the terminal voltage as a given value, which can obviously smell the smell of burning. The above are the common reasons for the failure of diesel generators to generate electricity summarized by our editor. We hereby suggest that if your diesel generator has not expired, please contact the diesel generator manufacturer to provide guidance on operation, and try not to repair it yourself. More solutions, you can visit https://www.dbdieselgenerator.com
7/23/2022 8:14:35 AM • Yamaha... • Answered on Jul 23, 2022
2answers
How to fix surging
Very old thread but here goes., My 2400is was surging under light load but I was able to fix that with a new idle jet and thorugh carb cleaning. Now, it doesn't respond to various loads and will not rev up, ie., stays at idle and quits. Manually opening the throttle works fine. I took out the solenoid and cleaned the spindle but didn't help. When it was out, turning it had some resistance (felt like a rehostat, a bit rough and definitely not spinning freely) . Dunno how it should feel but, for example, with the engine not running if I move the throttle (controlled by the solenoid) it will "stick" in that position and not return to the idle position by the return spring. Would like to know if that's normal or not! With the engine running, it will return to the idle position and I use a clothespin to keep the revs up even under no load. At least that way it stays running and supplies adequate power. Ideas?
3/16/2022 11:54:42 PM • Yamaha... • Answered on Mar 16, 2022
Yamaha EF6600E generator hard starting and stalls when demanding power
The OHV engine requires periodic valve adjustment.
9/16/2021 9:24:48 AM • Yamaha... • Answered on Sep 16, 2021
Yamaha ef 1400 generator runs but not producing power
Check the brush holder for worn brushes. If they seem ok then the voltage regulator has failed.
5/23/2021 10:50:16 AM • Yamaha... • Answered on May 23, 2021
Yamaha 2000 generator won't produce power, runs fine otherwise
The generator does not operate in accordance with the specified technical conditions, such as too high stator voltage, iron loss increases; if the load current is too large, the copper loss of the stator winding increases; if the frequency is too low, the cooling fan speed becomes slow, affecting the heat dissipation of generator; the power factor is too low, so that the rotor excitation current increases, resulting in the rotor heating. Check whether the indication of monitoring instrument is normal. If it is abnormal, necessary adjustment and treatment must be carried out to operate the generator in accordance with the specified technical conditions. Diesel generator set more supports: www.dieselgeneratortech.com
4/11/2020 3:13:58 AM • Yamaha... • Answered on Apr 11, 2020
Can a Yamaha YG6600D be converted from manual start to electric. Does the flywheel come fitted with a ring gear.
If you plan to purchase a new diesel generator set, please visit at https://starlightgenerator.en.made-in-china.com
12/9/2019 6:18:02 AM • Yamaha... • Answered on Dec 09, 2019
Where is the fuel filter on a Yamaha 1 kva. 7 CG 351679
Hi, maybe you can contact your supplier who supplies the generator to you. If you want to have diesel generator set in future, please visit at https://starlightgenerator.en.made-in-china.com
12/7/2019 5:54:38 AM • Yamaha... • Answered on Dec 07, 2019
Yamaha ef600 generator manualwont run basically anything except lights.burnt out electronic battery charger
More supports, please see at www.dieselgeneratortech.com
10/22/2019 1:34:53 AM • Yamaha... • Answered on Oct 22, 2019
My YG650DE Yamaha gen runs good but there is no electric power is there a reset switch or some other fix?
Here is some reasons for reference: 1.After the diesel generator is stopped, the residual magnetism is often lost, because the material used for the magnetic pole of the exciter is close to the soft steel, and the residual magnetism is small. After the shutdown, when there is no current in the excitation winding, the magnetic field will disappear. 2.The magnetic pole of the diesel generator loses its magnetic properties. 3.Damage of excitation circuit components or circuit breakage, short circuit or grounding phenomena. 4.The exciter brush is not in good contact with the commutator and pressure of brush holder is insufficient. 5.Excitation winding wiring error, opposite polarity. 6.Stator winding and rotor winding of generator set open circuit. 7.Poor contact between diesel generator brush and slip ring, or insufficient brush pressure. 8.Diesel generator lead wire wiring is loose or switch contact is poor. 9.The fuse box is fused. 10.The "auto-manual-de-excitation" switch on the control panel is in the de-excitation position (automatic generator set has "auto-manual-de-excitation" switch). 11.The voltmeter is damaged. 12.Rotary rectifier module is damaged.
10/22/2019 1:31:17 AM • Yamaha... • Answered on Oct 22, 2019
Yamaha 5500P industrial series generator. It started back firing and will almost die then power back up. Was running great then just one day started this. At first I thought condinsation as it seemed to struggle with gas then the major back firing. Any ideas please.
Start by replacing fuel. Completely drain the tank and carburetor fuel bowl. Do not use what fuel you may have, get 2 gallons of fresh fuel from gas station. If problem clears then likely water in fuel.
If still backfires with fresh fuel then likely an ignition issue. Failing ignition module or possibly a sheared flywheel key. Try reducing spark plug gap to .025" .
10/13/2019 11:12:35 AM • Yamaha... • Answered on Oct 13, 2019
Yamaha ef7200 d generator only putting out 32volts. Whats wrong
Mybe the problem is the frequency. Visit the website www.dieselgeneratortech.com to get more support.
10/9/2019 3:32:41 AM • Yamaha... • Answered on Oct 09, 2019
Yamaha ef6300isde generator - 30 amp mode - flips to overload after about 5 to 10 seconds. Generator runs well and all other plugs work when switched to 120/240. Any ideas?
There are several types of overload to consider: A. Catastrophic: something has gone very wrong. There may be a phase to phase short or two shorts to ground. This assumes you have an ungrounded system. With luck the main circuit breaker will open without destroying itself; B. Steady state over current: The load on the generator is greater than the rating on the circuit breaker. Time to parallel in another generatoror shed load; C. Transient over current: Suppose you were running two generators in parallel and one failed. The remaining machine may experience an over current condition that causes the breaker to trip. You can also have transient breaker trips upon activation of a large motor e.g., fire pump or bow thruster; D.Thermal: There is a big difference in sea water temperature as you travel the world. It is possible to have an overload caused by the diesel engine's inability to shed heat in the tropics. Continued operation could damage the diesel engine. Again, parallel in another generator or shed load.
9/30/2019 2:02:17 AM • Yamaha... • Answered on Sep 30, 2019
Yamaha 2400 generator will run hour or 3, or just 30 minutes & shut off. Will ef2400 low oil sensor bypass will help me narrow down the issue. It has adequate oil level per manual
Yes, try to bypass oil sensor to evaluate problem. Defective oil sensors cause a lot of problems.
4/18/2019 3:00:14 AM • Yamaha... • Answered on Apr 18, 2019
Why do my lights flicker when running my generator it's a Yamaha y g 2800i
Is it overloaded? That's the most common reason!
3/24/2019 9:13:02 AM • Yamaha... • Answered on Mar 24, 2019
My yamaha 2800 generator will run for 10min then motor gets hot and shuts down
Check oil level and cooling air flow past the cylinder. Are there foreign material like leaves in the air intake?
3/17/2018 4:35:56 PM • Yamaha... • Answered on Mar 17, 2018
My Yamaha ef2400is keeps surging while idling
Probably find that the carburetor jets are a bit clogged. Remove and soak in carburetor cleaner and then blow out with compressed air. Or alternately get a very fine drill set and clean, but be careful if choosing this method. Also clean the air filter. cheers
2/19/2018 12:24:18 PM • Yamaha... • Answered on Feb 19, 2018
How do you adjust voltage output on new Generac
You may find the following documents helpful for troubleshooting and parts. I use www.arcolawn.com for parts but any reseller can assist you. This model does have an adjustment on the AVR behind the main panel but please review the below manuals before adjusting. Material Number Manual (PDF) 0H4099 EV C/PNL 410 XG PORTABLE 6.5KW 0H5145 WD SD 8.0KW XG ES 0J1587A EV XG8000ES 49ST 0J2873 EV XG8E 410CC 0J4651 MANUAL LOWES XG8000E 0J3335A WARRANTY STATEMENT EMSN E1 P3
2/13/2018 4:38:11 PM • Yamaha... • Answered on Feb 13, 2018
Hi I got a 3000 yamaha generator with no output what ya think problem could be
voltage regulator not producing volts for the exciter windings of the alternator
1/16/2018 3:38:46 AM • Yamaha... • Answered on Jan 16, 2018
Yamaha Wave Runner Iii Vxr Blaster Pro Raider Gp 700 650 Flywheel Cover Logo
3 questions posted
Top Yamaha Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Electrical Supplies
Most Popular Question
1994 yamaha
  • Electrical Supplies
