Question about Yamaha Electrical Supplies
Where is the fuel filter on a Yamaha 1 kva. 7 CG 351679
Posted by Bob gough on
sherlywang
    Master:
  • 425 Answers
Hi, maybe you can contact your supplier who supplies the generator to you.
If you want to have diesel generator set in future, please visit at https://starlightgenerator.en.made-in-china.com
Posted on Dec 07, 2019
1 Related Answer
epettingill
Gruber Power Services
  • 176 Answers
SOURCE: Have (2) 7 kVA's &
Please Call me at Gruber Power Services tech support. It's free tech support. Ask for Eric
Posted on Aug 24, 2011
Carburetor
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
yamaha yz125 Choke for carburetor Google Search
Yamaha yz125 look over and carb help
Yamaha YZ125N1 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 27, 2014 | Yamaha YZ 125 Motorcycles
Won't start without choke
Motorcycle Message Board Motorcycle USA
http://www.r6messagenet.com/forums/r6-maintenance-technical/117461-wont-start-without-throttle.html
1999 2002 Yamaha YZF R6 Service Manual R6 Moto Data Project
Jan 08, 2014 | 1999 Yamaha YZF-R6
Yamaha tw200 runs with full choke only
Yamaha TW200 Trailway Discussion Forum
sputtering will only run with choke dies with gas
Yamaha TW200 Service Manual
YAMAHA TW200E Owner Manual
Feb 16, 2013 | 2010 Yamaha TW200
Does a yamaha zuma 125 have a fuel filter
Hi, Anonymous "ABSOLUTELY" for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic Zuma 50 fuel filter
Scooter Fuel Filter Replacment How To
http://z125data.weebly.com/uploads/7/1/2/2/7122816/zuma_125_service.pdf
Yamaha Zuma YW125A Owner Manual
Jan 22, 2013 | 2011 Yamaha Zuma 125
1995 Yamaha XJR 1200 cold start problems
Hi, Iain and the usual suspects are:
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Starting Problem Workshop Help
legend cold start problems
YAMAHA XJR1200 FACTORY OWNERS REPAIR MANUAL 1995 2006 Download Manuals... $24
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jun 15, 2012 | 1995 Yamaha XJR 1200
Road star will only start when using starting fluid. Has new fuel pump installed
Hi, Bakers10257 and the usual suspects are:
Re 01 Road Star will not start Road Star Forum Yamaha Road Star
http://www.fireblades.org/forums/honda-cbr-600/80304-starting-problems-turns-over-but-only-starts-starting-fluid.html
Yamaha XV1700P Service Manual
Yamaha Road Stan XV17AT Owner Manual
May 20, 2012 | 2003 Yamaha Road Star Silverado
2000 Yamaha WR400 wont run with choke off.
WR400 won idle choke
Help 2000 wr400 won idle off choke What could it be motorcycles
YAMAHA WR426F Owner Service Manual
YAMAHA WR450F Owner Manual
May 19, 2012 | 2000 Yamaha WR 400 F
Have (2) 7 kVA's & (1) 18 kVA Best. Need fans for all 3. What is the P/N and the cost?
Aug 08, 2011 | Powerware FerrUPS 5.3KVA (fj340aa0a0a0a0a)...
2001 Honda CG 125 Cargo will not idle
Hi, Eric19573 "ABSOLUTELY" otherwise the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
6. Float cracked, leaky or damaged.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Float bowl vent or overflow tube clogged.
9. Fuel flow to carburetor restricted.
10. Intake manifold leak.
11. The gas cap is not venting properly or fuel tank venting system blocked.
12. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
13. Needle and seat stuck closed in the float bowl.
14. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.pistonheads.com/gassing/topic.asp?t=1411860
Please help Honda CG125 running probs Easy fix for you clever guys
https://www.demecanicos.com/manuales/honda_cg_125.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda CG125 Fan Owner Manual
May 07, 2011 | 2001 Honda CG 125 Cargo
Electrical Supplies Logo
142 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
