Question about Yamaha Electrical Supplies
Yamaha 2400 generator will run hour or 3, or just 30 minutes & shut off. Will ef2400 low oil sensor bypass will help me narrow down the issue. It has adequate oil level per manual
Posted by Dwayne J Prickett on
Chuck Graybill
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 104 Answers
Yes, try to bypass oil sensor to evaluate problem. Defective oil sensors cause a lot of problems.
Posted on Apr 18, 2019
5 Related Answers
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Posted on Mar 12, 2009
Anonymous
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
MrJunk
  • 12 Answers
SOURCE: I have a Coleman Powermate pm0545007 generator
there should not be pinched wires...
if you mean "how do I bypass the low oil SENSOR" then the answer is to just disconnect it and tape up the end or snip it off in a location where it won't ground out...the way these engines kill the spark is by grounding the cdi coil wire...so fix that pinched wire and youre probably good to go...dont disconnect the low oil sensor unless its causing trouble....having low oil protection is good and might save you from blowing an engine
Posted on Jul 03, 2010
Anonymous
SOURCE: McCulloch generator stops after about a minute
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
Posted on Jul 12, 2010
Anonymous
SOURCE: Generac generator will start, run for a moment and
Its the Oil sensor just pack the oil sensor wires together with a smal screw and bolt and try starting if it starts your problem is the oil sensor they tend to go bad I have run through several myself . To avoid hassles I now have overidden the sensor but I check the oil level everytime I need to use the generator
Posted on Sep 03, 2010
Valve sticks. Runs for less than a minute and then shuts down.
Ed,
We would love to help you out!
First,check the oil level is to the very top of the filler as these have an automatic shut off if the oil gets too low. They like to be filled to the very top of the filler hole. Try running it, if it still shuts down let us know and we will assign an Engineer to your case. :)
http://www.generatorguru.com/ask-the-guru/
May 11, 2016 | Yamaha YG6600DE Generator
Runs but shuts off automatac
check the oil, most of these have a low oil shut down. If it's full make sure it's sitting level while running. If it still shuts down and is full of oil and level, bypass the low oil shutoff and see if it stays running.
Dec 04, 2012 | Coleman Powermate Premium Plus 6250W...
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Yamaha ef 2400is starting
The manual contains a schematic which does not show a heat sensor. You need to narrow it down to a fuel or spark problem. The easiest to check is spark. If you do not have spark, it could be the plug, wire, oil level sensor, magneto, coil or TCI module. If you have spark, then it is likely a fuel problem. Open drain and see if fuel is getting to the bowl. If not, check tank, valve and lines. If yes, it must be the carburator. Good luck.
Jun 09, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Starting
try checking the oil. it might be low
Generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Sep 20, 2008 | Electrical Supplies
Electrical Supplies Logo
155 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
