Question about Yamaha Electrical Supplies
Yamaha ef6300isde generator - 30 amp mode - flips to overload after about 5 to 10 seconds. Generator runs well and all other plugs work when switched to 120/240. Any ideas?
Posted by Matt Orist on
sherlywang
    Master:
  • 425 Answers
There are several types of overload to consider:
A. Catastrophic: something has gone very wrong. There may be a phase to phase short or two shorts to ground. This assumes you have an ungrounded system. With luck the main circuit breaker will open without destroying itself;
B. Steady state over current: The load on the generator is greater than the rating on the circuit breaker. Time to parallel in another generatoror shed load;
C. Transient over current: Suppose you were running two generators in parallel and one failed. The remaining machine may experience an over current condition that causes the breaker to trip. You can also have transient breaker trips upon activation of a large motor e.g., fire pump or bow thruster;
D.Thermal: There is a big difference in sea water temperature as you travel the world. It is possible to have an overload caused by the diesel engine's inability to shed heat in the tropics. Continued operation could damage the diesel engine. Again, parallel in another generator or shed load.
Posted on Sep 30, 2019
5 Related Answers
Anonymous
  • 96 Answers
SOURCE: overloaded generator
Check a see if it is when the unit is starting up when the over load happens if so you need a hard start kit
Posted on Dec 14, 2008
Anonymous
  • 152 Answers
SOURCE: 20amp or 40amp
Well 20 amps at 120V is only 2400 Watts. So yes each recepticle can handle 20 Amps. For a total of 4800W Continuous. The head room Between that and 5500W is generally for starting motors and inrush currents.
Posted on Dec 23, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: I HAVE A EF2800i YAMAHA GENERATOR. WHEN I TURN ON
Your generator does not have enough wattage to run an AC.
Posted on Mar 02, 2011
chris logan
  • 13 Answers
SOURCE: I have an overload alarm on my honda eu2000i
it may be a thermal coupler that cuts out when it gets to hot i would let it cool off for a bit then try it with a lighter load and go from there
Posted on Jul 28, 2011
Amador Lopez
SOURCE: Error Codes kde6700ta generator
what code you have???
Posted on Sep 18, 2012
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
Yamaha EF6300isde inverter generator is starting to spit oil out the hot air exhaust vent on the back. Not THE engine exhaust, just the hot air vent. Has the single cylinder 357cc Yamaha engine.
If you are referring to the crankcase ventilation, it could be that either the engine is overfilled with oil, or the cylinder could be glazed and the engine requires a moderate to heavy load every so often to prevent this from occurring.
I would recommend that you stick with mineral oil with a grade of 10w/ 30, even better just use the OEM stuff, or Honda 10w/30 is easily available.
Some of these small engines have a chrome bore and do not like synthetic oils, it will cause cylinder glazing and excessive blow by.
Change the oil when it is starting to become contaminated, ie. getting carbon in it, rather than guessing at hours of operation.
If it's not the CCV your referring to, it must be leaking oil from the engine somewhere and blowing back via the cooling fan, this will require a thorough clean and further investigation to diagnose correctly.
Most common areas of oil leaks are the crankshaft seals and valve cover gasket.
I personally would start with an oil change to mineral, and place generator on a loaded circuit for a while, don't kill it just load it, and see if you have any improvements.
Hope you find this helpful.
Feb 21, 2018 | Yamaha EF6300iSE - 6300 watts/52.5 amps...
Yamaha 2400IS Generator goes to overload when ie: 240 volt plugged in, or 700 watt angle grinder plugged in.
No idea but somebody else will probably come along with a better idea then mine, seems a lot of these generators have this thing installed on them (Has $25 hard start kit). Not sure what it does or how it works. Strangely enough you said you use it for 240 volt. Looked at the picture and didn't see a 240 volt connection.
If you are using the what look like the 120 volt circuits you can't over load the unit. Maximum current draw will cause it to go into protection mode and shut down the power load. The following is an exert from the owners manual which I got from Yamaha's site. Link at the end of this post.
Hope this helps
16
q
760-029
AE00788
Overload indicator light
The overload indicator light
comes on when an over-
load of a connected electrical device is detected, the
inverter control unit overheats, or the AC output voltage
rises. The electronic breaker will then activate, stopping
power generation in order to protect the generator and
any connected electric devices. The AC pilot light
(green) will go off and the overload indicator light (red)
will stay on, but the engine will not stop running.
When the overload indicator light comes on and power
generation stops, proceed as follows:
1. Turn off any connected electric devices and stop
the engine.
2. Reduce the total wattage of connected electric
devices within the application range.
3. Check for blockages in the cooling air inlet and
around the control unit. If any blockages are found,
remove.
4. After checking, restart the engine.
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
Jun 06, 2016 | Yamaha EF2400iS Portable Generator
Runs but will not generate power
Make sure the generator breaker switch is flipped on to allow voltage and amps to flow to the recepticals. Otherwise, if the switch is on, then you have overloaded the generator and blown a capacitor, resistor or similar item and the gen needs to be serviced.
Dec 03, 2013 | Briggs & Stratton Electrical Supplies
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
20amp or 40amp
Dec 22, 2009 | Tools & Hardware - Others
Overloaded generator
Dec 14, 2008 | Dometic Rooftop RV Air Conditioner
Electrical Supplies Logo
204 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
