FixYa.com
IBM UltraStar 9ES 9.1 GB Hard Drive
All Products > IBM > Hard Drives
Problems with IBM UltraStar 9ES 9.1 GB Hard Drive?
Search inside IBM UltraStar 9ES 9.1 GB Hard Drive Knowledgebase
Troubleshooting and Support
Solved Problems for IBM UltraStar 9ES 9.1 GB Hard Drive RSS Feed Post a New Problem
setting this drive as a slave
how can i set this drive as a slave?
1 Solution
Windows 98, IBM 9ES, Adaptec 1542CF -...
Some help please, I have an IBM 4 gig 9ES with the above mentioned software/hardware. FDISK under Windows 98 only...
2 Solutions
Replaced SCSI HD DDRS-39130 Problem
Hello everyone! I hope someone can help me with this. Last night while booting my PC I got a message in DOS saying...
2 Solutions
Problem between 2930 and HDD IBM DDRS...
During the boot of windows 98, the syst??me halt during 35 secondes and continue to boot after this 35 s. I have test...
1 Solution
disk crash data recovery
At first my system was slow, then I got endless error messages on delayed write. When I tried to run scandisk it failed...
1 Solution
My hard drive is nearly full, so I added...
My hard drive is nearly full, so I added an additional drive which I made active and non bootable. Will I have to...
1 Solution
my harddrive went out on my pc. is there a...
my harddrive went out on my pc. is there a way to by pass my harddrive so i can get online or burn cds on...?
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
InterfaceSCSI · IDE/EIDE
Form FactorDesktop Computer
Capacity9.1 GB
EnclosureInternal
Spindle Speed7,200 RPM
Drive Dimensions3.5" · 3.5" x 1/3H (Low Profile)
Technical Features
Buffer Size512 KB · 384 KB
Special FeaturesS.M.A.R.T Technology
External Data Transfer Rate40 Mbps · 80 MBps · 20 MBps
Interface (Detailed)SCSI-3 Ultra Wide (16-bit) · SCSI-2 Fast Wide (16-bit) · SCSI-3 Ultra (8-bit)
SCSI Signaling TypeLow Voltage Differential (LVD) · SCA-2 · Single Ended (SE) · SCAM level 2
Seek Time7.5 ms
Average Latency4.17 ms
Internal Data Transfer Rate171.12 Mbit/s
Sound Emission48 dB
Other Features
PlatformPC
Package Qty.1
Dimensions
Depth5.75 in.
Height.99 in.
Width4.02 in.
Weight1.32 lb.
Warranty
Warranty5 Years · 3 Years
Supported Models
00K3970, 00K3990, 00K4010, 00K4149, 10L6085, 22L0211, 22L0231, DDRS-39130
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
