FixYa.com
IBM NetVista PC Desktop
All Products > IBM > PC Desktops
Problems with IBM NetVista PC Desktop?
Troubleshooting and Support
Solved Problems for IBM NetVista PC Desktop RSS Feed Post a New Problem
Old Computers.
Do you take old computers for recycling or refurbishing for schools?
1 Solution
Screen goes blank on Log on
Running Windows XP with ATI Radeon X300 128Mb PCI card. Screen OK up to log on screen. When you log on screen goes...
1 Solution
starts then reboots
My computer starts well when i try to go on line it reboots, Or whenever i try to give it some work. There was a virus...
1 Solution
BIOS set up
On booting, I receive a message that my system has been tampered with I have read that I can reset this "System...
1 Solution
Re-installing operating system
I'm am trying to re-install the WinXP operating system onto a new second hard drive while retaining the original OS on...
1 Solution
Drivers problem
My ibm 8307-32u is not piking vga,audio,network & CD drivers when i installed win xp Professional, i tried the...
1 Solution
ibm netvista cannot boot
my pc cannot boot from the windows xp cd
2 Solutions
View All
Unsolved Support Problems
Unsolved Problems for IBM NetVista PC Desktop RSS Feed Post a New Problem
BIOS set up
I am using XP on an IBM Net Vista desk top. By pressing various keys during boot up - F2, DEL, etc. - I get to differnt...
Post a Solution
power supplay of d530 and 5000
Hello! My name is Lev Rosenblum and i work in lab with d530. My problem is red led after i have had change fuse...
Post a Solution
Moved Computer, 150 miles and Memory fell...
A close friend was kind enough to give me his " Good Used ", Net Vista 6833 Mod. 25U. Well when we were...
Post a Solution
Network
I am trying to connect two computers so that one is the slave of yhe first. I have two ethernet cables and a hub, but am...
Post a Solution
touch screen wont work
I am a newbie how do I upload the file you recomended to my iphone, thanks in advance
Post a Solution
IBM NetVista Doesn't Start up
Similiar to this link http://www.fixya.com/support/t657962-ibm_netvista_power_up I was just going to start using this...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Operating SystemPC DOS · Microsoft Windows XP Professional · Microsoft Windows 2000
Form FactorTower · Micro Tower · Desktop
ProcessorIntel Pentium 4 2.53 GHz · Intel Pentium 4 1.8 GHz · Intel Pentium 4 2 GHz · Intel Pentium 4 1.6 GHz · Intel Pentium III 970 MHz · Intel Pentium 4 2.4 GHz
Installed Memory512 MB (DDR SDRAM) · 256 MB (SDRAM) · 256 MB (DDR SDRAM) · 128 MB (DDR SDRAM)
Recommended UseCorporate Business, Small Business · Small Business
ChipsetIntel 845 · Intel 815E · Intel 845G
Processor
Processor TypeIntel Pentium 4 · Intel Pentium III
Processor Speed2.53 GHz · 1.8 GHz · 2 GHz · 1.6 GHz · 970 MHz · 2.4 GHz
Processor ManufacturerIntel
Processor UpgradabilityUpgradable
Max Processors Qty.1
Installed Qty1
Socket TypeSocket 370
Motherboard
Bus Speed400 MHz · 133 MHz
Video Output InterfaceAGP 4x · AGP
Memory
RAM TechnologySDRAM · DDR SDRAM
Installed RAM256 MB · 128 MB · 512 MB
Installed Cache Memory512 KB · 256 KB
Max Supported RAM2 GB · 512 MB · 1.5 GB
Installed Video Memory16 MB
Supported RAM Speeds266 MHz · 133 MHz
Number of Memory Slots2 x DIMMs · 2 x 184 Pin DIMMs · 3 x 168 Pin SDRAM DIMMs
Technical Features
Expansion SlotsAGP x4 x 1 · PCI x 3
Integrated Input/Output PortsSerial Port x 2 · USB 2.0 x 2 · USB 1.1 x 4 · Serial Port x 1 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · USB 2.0 x 6 · RJ45 Lan Port x 1
Expansion Bays1 x 3.5" (Internal Access) · 1 x 3.5" (External Access) · 2 x 5.25" Half-Height (External Access) · 1 x 3.5" Third-Height (External Access) · 1 x 3.5" Third-Height (Internal Access) · 1 x 5.25" Half-Height (External Access) · 2 x 3.5" Third-Height (External Access)
Security FeaturesBoot Sequence Control · Boot Without Keyboard or Mouse · Diskette I/O Control · Parallel Port I/O Control · U-Bolt Anchoring Feature · Serial Port I/O Control · Hard drive I/O control · Diskette Boot Inhibit · Slot For Cable Lock · Power-On Password · Administrator Password
Power ConfigurationsACPI/APM Power Management · Wake On LAN Header · Wakeup from Keyboard/Mouse
Hard Drive
Controller TypeEIDE · DMA/ATA-66 (Ultra)
Hard Drive Capacity40 GB · 20 GB · 30 GB
Hard Drive InterfaceEIDE · DMA/ATA-100 (Ultra) · DMA/ATA-66 (Ultra) · IDE
Hard Drive Rotation Speed7,200 RPM · 5,400 RPM
CD / DVD
Optical Drive TypeCD-ROM · CD-RW · DVD-ROM
Optical Drive Read Speed16x (DVD) · 48x (CD) · 40x (CD)
Other Drives
Floppy Drive3.5" 1.44 MB floppy
Audio / Video
Audio Output TypeSound Card · Headphones · Line Out
Max. Video Resolution1600 x 1200
Graphic ProcessorNVIDIA Vanta · Intel Extreme Graphic
Audio InputMicrophone Jack · 1 x Line In
Video Out Ports15 Pin D-Sub VGA port x 1
Integrated AudioAC'97 Audio Codec
Warranty
Warranty3 Years
Networking
Data Link ProtocolEthernet · Fast Ethernet
Networking TypeNetwork Adapter · Integrated Wireless LAN · Integrated 10/100 Network Card
Dimensions
Depth15.72 in.
Height16.35 in.
Width7.49 in.
Weight29.55 lb.
Supported Models
6578WM6, 6579P3UGIEE24, 6790G40, 6790XX3, 6790XX4, 679232UGJMF3406, 6792-XX2, 6793-XX3, 6794XX9, 6795MCU, 825633216501, 8303SPU, 8306LFU, 8307XXX, DTIBMP42400-X11, DTIBMP42G-XX7, RBDTP42400X11, RBDTP42GXX7, RB-IBMP42400, RBP42400, RBP424008307
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
