When I turn it on, the display screen is dark and when I hit the return key, numbers show up on the display screen, but that's it. not sure what's wrong with it. I did change the batteries, but that didn't fix the problem.
SOURCE: IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
SOURCE: IBM WheelWriter 30 Series II
The 121 indicates a keyboard problem, See my tip under ww1000 also check the two flat connectors from the KB to the PC mboard.
DickyO
SOURCE: IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
SOURCE: only part of a letter appears when typed
You can try code I to increase the impression but probably the print solenoid is gummy or the plastic solenoid is broken. We sell the caps with installation instructions for 20.00 includes freight. DickyO Cleveland Business Machines 216-241-0027
SOURCE: IBM Wheelwriter 30 Series II issue...
This is automatic return, it can be turned off with code "R".
You can download a manual at lexmark.com click on publications.
DickyO
