20 Most Recent HP Black 15.6" 2000-369WM Laptop PC with AMD Dual-Core E-450 Questions & Answers
My screen went black while online how do I get back?
Black screen during login can happens for a few reasons. And there is a few solutions to it. But, one main thing is to ensure that your machine is free of viruses, malware and trojans. To do this, enter safe mode, install antivirus and scan your whole system. There is only few antivirus that can be installed in safe mode i.e : ThreatFire. Then, you should scan the drive. 1. Depending on your OS, sometimes, it happens due to incomplete updates. This cause crashes within the system and causing the driver to receive black signal. To solve this, try to resuscitate the system by going in to safe mode, enter cmd and run the "sfc /scannow" options to ensure that all vital files is intact. 2. It also can be caused by fault hardware or recent failure of updates for the graphic driver. If so, you can rollback the changes using windows restore or, reinstall the driver and use the 'standard' driver that windows has for a while before you install the updated driver. 3. if none works, install a clean windows without removing the data. Place the new windows in the same installation drive as previous one and your data will be moved to Window.old folder. It helps.
12/3/2014 8:03:06 AM • HP Black 15.6"... • Answered on Dec 03, 2014
2answers
Transfer music from my HP Laptop to my Walkman some songs on my Walkman will not play instead CANNOT PLAY LICENSE NOT VALID will come on screen, music is from my CD collection put on my laptop
The message means the music is copy protected and that means it will not play outside the device it was downloaded to, in your case the Walkman.
5/14/2019 1:12:38 AM • HP Audio Players... • Answered on May 14, 2019
My widows 10 hp is very slow how can i change it to be normal again?
your PCs husband died, sorry my bad.... LOL slow is a subjective term , to me all PCs are slow. (unless I lay my grimy mitts on them) How much RAM do you have 1gig? is your HDD full? did you upgrade to SSD but wise if fast is your aim, is the PC infected. ? is your AV engine running, at least windows defender + free malwarebytes. what music where, mp3 files in a folder? or what are they? the extension of the file name matters. mp3 is common, wav is too but are huge and slow, but best sound of all. how many are there, 10 or 10,000.? what player are you using,.? I'd never touch MS media player ever. not me,? run fast free players that don't track you. if most windows screens are fast, and only MP3s are slow say that first. if all things are slow say that. I can not guess or see you do things. (my PC has over 100apps and runs fast) try BOOM player free. https://perkele.cc/software/boom lean and mean, and supports : MP3, Ogg Vorbis, FLAC, Musepack (MPC), WavPack, WAV, AIFF, MP4/M4A, WMA. or get VLC from, French, it runs too fast and not spyware. I love VLC, as to 100s millions of others. if all of windows acts slow run CCcleaner, free. find the free on. defrag your hdd if it is a hdd, if the hdd is near full , clean it out of old things not need or clone it to a larger HDD. better to SSD. safe and (makers page) https://www.videolan.org/vlc/
10/31/2018 4:55:05 PM • HP Audio Players... • Answered on Oct 31, 2018
3answers
I want a sound device to my computer
You need to download the audio driver from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the driver you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
www.hp.com/#Support
9/27/2018 10:46:46 AM • HP Audio Players... • Answered on Sep 27, 2018
HP Pavilion dv6915nr will not boot - continuously reboots ..
Unplug any external devices except the mouse, keyboard and monitor. Try booting that way. If that doesn't work open the side cover and remove the data cable and reinsert it on the hard drive. Do the same for the power cable. Sometimes that's all it takes. If is still doesn't work, then have the power supply tested to make sure all operating voltages are present.
1/30/2018 6:23:24 AM • HP Audio Players... • Answered on Jan 30, 2018
HP ms6000 keeps locking up
Logon the HP website: www.hp.com for US and go to support and run diagnostics for other countries use the two letter country code www.hp.com/uk
1/15/2018 8:03:18 PM • HP Audio Players... • Answered on Jan 15, 2018
I bought HP full size heavy duty (or so I thought)
Return it to the store with the receipt.
1/13/2018 12:17:23 PM • HP Audio Players... • Answered on Jan 13, 2018
0answers
Can I use a hp 18.5v 3.5a adapter with my creature 2 subwoofer or is too hot?
Look on your sub to see what voltage and ampere and watt it needs.
5/30/2017 6:39:54 PM • HP Audio Players... • Answered on May 30, 2017
The subwoofer jack on my HP 5187-2105 computer speakers does not work. How do I repair the situation?
Replace the jack if it is being powered.
1/30/2017 4:07:05 PM • HP Audio Players... • Answered on Jan 30, 2017
When it is connected to a laptop it says device is disabled because the firmware of the device did not give it the required resources. (Code 29)
Go to Hp's website and get the firmware update and how to install it for the player. Install the firmware update.
8/12/2016 8:53:42 PM • HP Audio Players... • Answered on Aug 12, 2016
HP Black 15.6" 2000-369WM Laptop PC with AMD Dual-Core E-450 Logo
2 questions posted
Top HP Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
ADMIN Eric
ADMIN Eric
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • HP Audio Players & Recorders
Most Popular Question
screen went black while online get back
  • Audio Players & Recorders
