Speakers worked fine at my brothers with his phone; and my laptop can pair with my phone ok,
SOURCE: My technics se hd 51
please bring a good contact cleaner from radio shack near you and apply the spray over the socket of the headphone(the place where you put your headphone jack)take headphone jack out and apply spray in and insert the jack in and out many times.-also check your system setup and confirm that all speaker are on- no mute button pressed-no cable is disconnected.
SOURCE: cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
SOURCE: Barely hear music from ipod when connected in aux Alpine CDA9835
Are you connecting the ipod through the green that is sticking out the back of the unit? If this is the case this is the amp output. I first hooked my ipod to this and has the same problem you describe. You actually need to purchase this part KCA-121B-Auxiliary-Input-Adapter.html">http://www.crutchfield.com/S-a7wrrbtQT1B/p_500KCA121B/Alpine-KCA-121B-Auxiliary-Input-Adapter.html in order to hook up your ipod up.
SOURCE: Insignia NS-BTHDP ok with phone, pairs with PC but can't connect
Make sure the headphones are set as "default" under Control Panel>Hardware and Sound>Sound>Manage Audio Devices - same for microphone if you're using it for online speech.
SOURCE: I installed the motion sensor
Leviton manuals:
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=17219&minisite=10022
A quick peek inside a sample Leviton manual confirms that your wires are connect correct - BUT...
http://waterheatertimer.org/pdf/Leviton-motion-Instructions.pdf
The remaining 3-way switch needs a jumper wire.
See if your instruction manual shows the same thing as image below.
Let's go through this.
The yellow wire connects to a traveler ... and that traveler connects to one of the brass screws on 3-way switch.
The black wire from Motion sensor also connects to a traveler wire ... BUT you have to identify which traveler wire and which brass screw that traveler wire connects to. And then, put a jumper wire (a short piece of wire) from that brass screw to the dark-colored screw.
I think that will do it.
Add a comment if your device is different.
Some of these electronic devices are reversed when two of their wires are connected together.
That's what the jumper wire is doing. So the 3-way switch is just connecting and disconnecting the black and yellow wires, and that action reverses the circuit in the motion device.
