Question about HP Audio Players & Recorders
HP Pavilion dv6915nr will not boot - continuously reboots ..
Will not boot was using it shut down and the led lights blink and the fan runs on and off but the screen stay's black. the icon at the bottom which indicates that it is booting doesent light up. please help I have picture's on ther of my kids and would hate to loose all of this
Posted by chris scarborough on
Lawrence Oravetz
  • HP Master
  • 10,543 Answers
Unplug any external devices except the mouse, keyboard and monitor. Try booting that way. If that doesn't work open the side cover and remove the data cable and reinsert it on the hard drive. Do the same for the power cable. Sometimes that's all it takes. If is still doesn't work, then have the power supply tested to make sure all operating voltages are present.
Posted on Jan 30, 2018
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Posted on Aug 16, 2008
bentsteel
SOURCE: HP Media Vault - Power on / fan on / front panel indicators off
I read a bunch of material found on the web. Primarily this led me to believe that the Lynix flash OS has some issues (to say the least). After carefully testing out the mom board voltages I decided that there was probably a software boot issue.
I read this at k0lee.com/mediavault/
"The MV1 has a hard reset which severs the tie to the startup.sh script that calls any of the installed software." The material on this site also indicated that the stored files would not be affected by a hard reset. So what the heck... nothing to lose. I unplugged the power, pressed the reset button and then applied power. Held the reset button for > 5 seconds. Held my breath for 30 seconds and the disk light started to flash on the front indicator panel. After a minute or two of that, the OK light came on. I pressed the power button on the front panel and the it responded. Another miracle? Hmmm. The MV shut down. I connected to the LAN and powered back on. Every thing worked fine.
I guess... there was a space issue / startup parameter corruption / enemy electron in the mix that was passed over with the hard reset at start up. Since there is on access to the OS boot process, (or source code) this is pure speculation. Although, it is reasonable speculation. Chao!
Posted on Dec 01, 2008
Anonymous
  • 224 Answers
SOURCE: my acer one netbook won't boot
This is a common problem with the Acer Aspire one. Apparently, the BIOS needs to be flashed using a flash disk with the required files.
Unfortunately, the files are not available at any website but you can take the Aspire one to any Acer service center and they should be able to flash the BIOS for you free of cost.
Posted on Mar 16, 2009
Anonymous
SOURCE: WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
Posted on May 22, 2009
benwabnick
Ben Wabnick
  • 2404 Answers
SOURCE: hp pavilion a465c desktop which will not boot
Make sure the power supply switch on the back is set to 115v, its normally a red switch but could be black.
Once you do that see if you can turn on the computer and get video.
If not then with the computer turned off, take out the memory sticks and reseat them one at a time in each slot one at a time and try turning on the computer to see if you get video. If you still don't get video then try taking out the CPU and reseating it back into its socket properly. At the same time make sure there is no dust or dirt on the cpu or in the socket.
Try again and see if you get video. If you don't get any video this time then disconnect everything and only have power going to the motherboard. If you do this and you still don't have video then the motheboard is bad and would need to be replaced.
Posted on Aug 27, 2009
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
I have a hp special edition L2000. Power is getting to the computer as the LED lights come on and then continuously blink. I can feel the cdrom running in a start and stop pattern, much like the blinking...
try to recover first your data, remove hard disk and make it slave to other station. copy all your files. then you may now reformat using a fresh install of windows xp.
Apr 13, 2010 | HP Special Edition L2000 LiveStrong Mobile...
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
Computer freezes and shuts down and now says that i have fan failure as well computer will not boot up unless i go to boot screen and boot from hard drive this is a hp pavilion a1610n also it says i have a...
I would be careful if i was you because if it is a fan problem and you are starting up anyway your system can overheat and if that happens you just might be buying a new pc instead of a fan :) I use driveragent.com for all my driver needs. it searches your pc after you install it and finds any outdated or wrong drivers you might have and u can download them with a click of a button :) its a small fee but well worth it i used to have to search for hours trying to find drivers and then get a wrong 1 and continue the search
Oct 20, 2009 | HP Pavilion a1610n PC Desktop
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Hp pavilion dv2000 notebook will not boot up
Try un-install memory chip and re-install again.
Nov 16, 2008 | HP Pavilion dv2000t Notebook
73 people viewed this question
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
