20 Most Recent Garmin Nuvi 2360Lmt - Gps Receiver Questions & Answers
Only shows us routes not canada
2/16/2017 12:55:03 AM • Garmin Nuvi... • Answered on Feb 16, 2017
Where or how can I get a user manual for garmin 78sc unit
Have a look on their web site; https://static.garmincdn.com/pumac/GPSMAP_78_OM_EN.pdf&vssid=collectionitem-web-desktophttps://static.garmincdn.com/pumac/GPSMAP_78_OM_EN.pdf
1/4/2024 6:17:39 PM • Garmin GPS • Answered on Jan 04, 2024
My Garmin GPSMAP 78s shows me a Database Error each time i want to Mark a location or transfer files to i
I suggest you try resetting the device by following the instructions in the owner's manual. If the issue persists, it may be due to an error in the map database. You can try reinstalling the maps to the memory card after unlocking them for your device. If you are still experiencing issues, please contact Garmin Product Support for further assistance . Correcting the Message "Can't Unlock Maps" or "Can't Authenticate Maps" on a Garmin Automotive Device ' Garmin Customer Support
10/28/2023 6:16:31 PM • Garmin GPS • Answered on Oct 28, 2023
How to prevent Drive52 continually resetting itself ?
By 'resetting' you mean it switches off, and because it is connected to power, it boots back up. Do you have a SD Card in it? I had trouble with a Nuvi 1350 with SD Card that had the whole USA Map on it, mine came with the Canada Map only. It would randomly turn off, so I decided to buy a Factory Refurbished Drive 50. I removed the SD Card and Reset the Nuvi and it worked perfectly after that. The Drive 50 was also a bit flaky, and resetting fixed that as well. You can back up your Favourites beforehand.
7/21/2023 1:33:43 AM • Garmin GPS • Answered on Jul 21, 2023
I have the Garmin etrex 20x and wish to calibrate the compass
I recently purchased a Garmin GPSMAP 78s I had a lot of trouble calibrating the compass; I literally tried it hundreds of times without success. I also did a hard reset etc etc. Believe me I definitely tried everything possible but to no avail I did contact Garmin but they didn't have an answer straight away for the problem I have now sorted it as follows: Do each step VERY SLOWLY, MUCH slower than you think you should There are three steps to go through in calibrating the compass 1)Spinning the whole unit around flat 2)Flipping it over longitudinally and then 3) Flipping it over end to end. But remember do each step VERY slowly and go to the next step when prompted by the unit This solved my issue. I can now calibrate my compass 9 out of 10 attempts Hope that helps
7/16/2023 11:59:56 PM • Garmin GPS • Answered on Jul 16, 2023
Garmin nuvi 50LM cant access on mtp settings
To open the MTP settings on your Garmin Nuvi 50LM, you will need to access the device's menu. From the main menu, select the "Settings" option and then select the "System" option. From there, you should be able to access the MTP settings. If you are still unable to access the settings, you may need to contact the manufacturer for assistance.
1/29/2023 7:08:11 AM • Garmin GPS • Answered on Jan 29, 2023
3answers
How to Download Garmin Express Map Update in Windows ?
You will need to go to the Garmin website on your computer or laptop and set up an account. I think the sign up is free. You will then need to connect your Garmin to the computer and update it that way.
12/8/2022 10:07:14 AM • Garmin GPS • Answered on Dec 08, 2022
2answers
Garmin 120 wont turn on
Hi Earl, Sometime it could just be of aging. I have a 130, it was having similar problems, until i realized it was the screen not showing, but power on turning on. In your case, I probably probably try a hard factory reset as follows: To perform a master reset:
  1. Turn off the device.
  2. Press the PAGE, ENTER2, and POWER buttons simultaneously.
  3. Release all buttons once the Do you really want to erase all user data? message appears.
  4. Select Yes.
hope this helps! Kevin
12/8/2022 9:55:29 AM • Garmin GPS • Answered on Dec 08, 2022
Garmin etrex 10 click stick problem
It appears to be a known issue. You can try some Electrical Switch and Contact Cleaner in the first instance. This NOT WD40. https://www.google.com/search?q=Garmin+etrex+10+click+stick+problem ..
12/8/2022 4:25:25 AM • Garmin GPS • Answered on Dec 08, 2022
3answers
How To Resolve The Garmin Express Application Not Responding
notify garmin for assistance
12/7/2022 10:28:51 AM • Garmin GPS • Answered on Dec 07, 2022
2answers
I need to download USA & CANADA MAPS ,HOW DO I DO THIS,ONTO MY GARMIN NUVI2797
Normally you plug GPS into your computer and download map updates from Garmin website, I will post links below with Garmin instructions,manual,and software. press the helpful button nvi 2797 LMT Garmin garmin satnav hidden secret Installing microSD card Mapping on the Garmin nuvi 2797LMT and nuvi 2757LM Garmin nvi 2797LMT 7 Inch Portable Bluetooth Vehicle GPS with Lifetime...
11/30/2022 7:10:07 AM • Garmin GPS • Answered on Nov 30, 2022
2answers
How do I register my Garmin GPS
Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to register it, as well as provide any current updates.
11/15/2022 8:20:18 AM • Garmin GPS • Answered on Nov 15, 2022
4answers
How to fix Garmin setup issues?
Press the "reset" button to rest the unit....
11/14/2022 8:45:00 AM • Garmin GPS • Answered on Nov 14, 2022
Consertar ou substituir o LCD display do Garmin GPS III Plus
English only on Fixya. We are a North American website.
Fixing a Damaged Garmin Display Screen
https://support.garmin.com > en-CA If your Garmin's display screen is scratched, cracked, or broken, Garmin can offer an out of warranty replacement. To request replacement service, please ...
11/8/2022 5:57:02 AM • Garmin GPS • Answered on Nov 08, 2022
3answers
How to update garmin Niuive 650
Hello Download the Garmin Express application The Garmin Express application is used to update maps and device software on compatible GPS devices. Install the application on the computer Connect a compatible Garmin device Navigate the on-screen prompts The Garmin Express application will update the maps and / or software on the device.
11/1/2022 6:16:52 AM • Garmin GPS • Answered on Nov 01, 2022
2answers
I have a garmin forerunner 35 and this morning it started buzzing and vibrating on my arm. The battery ran down in about 15 min.
there cud be a malfunction or your battery is been damaged or dying, the life of any battery can goout according to how old the unit is you shud be able to find what ever you need at discount prices here>>www.discountbargainprices.com
10/27/2022 8:32:31 PM • Garmin GPS • Answered on Oct 27, 2022
3answers
My garmin in nuvi 1350 will not charge it keeps saying the battery is low
Nuvi 1350 charges in 4 to 8 hours. If your Nuvi is not accepting a charge, you may have a loose or bad USB cable. Note that the Nuvi can be charged with a phone charger. Charging it with a connection to a computer moves charging time toward 8 hours and more towards infinity if you don't have the driver installed on the computer. Turn the Garmin off. If the driver ins installed in the coputer, plug the Garmin into the computer and then hold down the power button on the Garmin for 30 seconds.
10/26/2022 6:42:19 AM • Garmin GPS • Answered on Oct 26, 2022
I Update My Garmin Nuvi 1450 GPS but it does not pick some locations. Now, How can I fix this Issue?
Best SOlution for Garmin Nuvi 1450 UPDATE:
  1. Connect the device to a computer
  2. Install the Garmin Express
  3. Purchase or access the Garmin Nuvi 1450 update
  4. Disconnect the Garmin Nuvi 1450
Apply these above steps to update the Garmin Nuvi 1450 GPS device. Now you connect it to your vehicle and you are good to go.
10/20/2022 6:50:44 AM • Garmin GPS • Answered on Oct 20, 2022
Garmin Nuvi 2360Lmt - Gps Receiver Logo
3 questions posted
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
Garmin GPS
  • Garmin GPS
Most Popular Question
only shows routes not canada
  • GPS
