GPS Logo
Question about Garmin GPS
Garmin 120 wont turn on
Posted by Earl on
Kevin C Tsai
    Problem Solver:
  • 8 Answers
Hi Earl,
Sometime it could just be of aging. I have a 130, it was having similar problems, until i realized it was the screen not showing, but power on turning on. In your case, I probably probably try a hard factory reset as follows:
To perform a master reset:
  1. Turn off the device.
  2. Press the PAGE, ENTER2, and POWER buttons simultaneously.
  3. Release all buttons once the Do you really want to erase all user data? message appears.
  4. Select Yes.
hope this helps!
Kevin
Posted on Mar 29, 2020
2answers
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102: http://www.uky.edu/~jmlhot2/courses/for480/Rino120_OwnersManual.pdf
Motorola TalkAbout user guides can be found at: http://shop.giantintl.com/Manuals.asp
Best regards.
2answers
I need to connect a Garmin 160 transducer to a garmin 120 fish finder
If I may inquire, how many pins on the transducer and on the fishfinder.
Hope to hear from you and pls post back the requested information.
Good luck and kind regards. Thank you for using FixYa.
I HAVE A GARMIN RINO 120 AND THE BATTERIES GO DEAD VERY QUICKLY. YOU CAN USE IT OUNCE TURN IT OFF AND THE NEXT TIME YOU USE IT THE BATTERIES ARE ALMOST DEAD.ALSO IT LOSES SATELITE SIGNALS AND TAKES A LONG...
An older unit. No service available from Garmin as it is obsolete. The 120's have a lot of problems. Poor battery life. Poor reboot and constant dying after on. I would find another unit.
3helpful
Instruction
Download or view the .pdf Rino 120 Owner's Manual here........
http://www8.garmin.com/manuals/Rino120_OwnersManual.pdf
4helpful
How to reboot rhino 120
reset is accomplished by holding the nav stick and the page utton while powering up and selecting yes to delete all data.
It is locked and wont unlock cause i do not have the code
Send it to Garmin with proof of purchase and they will unlock for you.
Turn it on - black screen
Dropped the rino 120 and the led is blank but radio works
2answers
To make un full reset
Hello Rahooty,
There is no way to set the date and time becayse the system clock in your Garmin Rhino 120 should be updating based on the information it receives from the GPS satellites. The radio should auto locate itself within about five minutes of being turned on providing it has a clear view of the sky. Once it sucessfully auto locates the radio's clock and position should reset. There does not appear to be any other reset built into the device.
Try taking the batteries out for at least 5 minutes. Then, reinstall the batteries, turn the unit on, and give the unit 5-10 minutes to auto locate. If it doesn't, you may need to contact Garmin support for additional sevice.
Best Regards,
Ken
"Go Ahead. Use Us."
Transfer data
Hello tompkin,
Programming the Garmin Rhino 120 using a PC requires an interface kit and may also require a RS-232 to USB converter cable or a 9-pin to 25-pin serial adapter depending on what interface is available on your computer.
The interface kit and cables are available on the manufacturer’s homepage for the product: www.garmin.com/products/rino120. Click on the “Accessories” tab and scroll down.
Best Regards,
Agent Ken
Go Ahead. Use Us.
1helpful
Garmin 120 will not turn on
i talked with garmin tech today, he said to hold the button below talk, and the wheel and the power at the same time to master reset....it did not work for me but it might for someone else
Top Garmin GPS Experts
Marvin
Marvin
Steve
Tom Chichester
Are you a Garmin GPS Expert? Answer questions, earn points and help others
