20 Most Recent Lexmark X656de Multifunction Monochrome Laser Printer/Copier/Fax/Scanner w/ Duplexing Questions & Answers
Good afternoon. My Lexmark 792 printer shows error 956.02 at startup when adjusting colors, how can I solve it?
The 956.02 error on your Lexmark 792 printer indicates a system board issue. Troubleshoot it step by step: Power off the printer: Turn off the printer and allow it to remain powered off for 10 to 20 seconds before turning it back on. Check the code level: You can identify the current code level using either of the following methods: Method 1: Print the Menu Settings Page: Touch the Menu button on the printer's operator panel. Select Reports. Choose Menu Settings Page to print the page. Look for the code level under Device Information. Method 2: Use the Printer's Embedded Web Server (EWS): Open a web browser (such as Internet Explorer) and enter the printer's IP address. Click on Reports and then select Device Information. Download and install the latest firmware: If your printer's code level matches any of the following: For C792: LHS1.HC.P129 or LHS1.HC.P130 For X792: LHS1.MR.P131, LHS1.MR.P135, or LHS1.MR.P135a For X925: LHS1.HK.P136a Proceed to download and install the latest firmware. If your printer's code level matches any of the following: For C792: LHS1.HC.P131 or later For X792: LHS1.MR.P135b or later For X925: LHS1.HK.P136b or later Contact Lexmark Technical Support for service. Update the firmware: Download the latest firmware from the Lexmark Support website. Save the file and extract it to the same directory. Use the appropriate Authorization Keycode: For Lexmark C792: c792 For Lexmark X792: x792 For Lexmark X925: x925 Update the firmware using one of the following methods: Embedded Web Server (EWS): Open a browser, enter the printer's IP address, and select Settings > Update Firmware. USB utility: Follow the detailed steps for updating via USB flash utility. USB thumb drive: Refer to the steps for updating using a USB thumb or flash drive. FTP: Follow the steps for updating via FTP. If you need further assistance, please contact Lexmark Technical Support. When calling, have your machine/model type and serial number (SN) ready. 956.01 system board error ' Lexmark C792 Error Codes > Lexmark > X792dtse > Code 956.02 (printcopy.info)
4/18/2024 4:49:05 AM • Lexmark Office... • Answered on Apr 18, 2024
What can replace the ibm lexmark wheelwriter 1000
If you're looking for a replacement for the IBM Lexmark Wheelwriter 1000, you might consider a typewriter like the Brother M-1000, the Olivetti Studio 45, or the Smith Corona SR8000. These typewriters have similar features and capabilities to the Lexmark 1000, and they're often considered to be good alternatives.
11/20/2023 6:00:27 PM • Lexmark Office... • Answered on Nov 20, 2023
My computer guy just installed Lexus Mint on my computer and downloaded the proper driver for Pantum 7100 series printer
How do you 'install' Lexus Mint green on your computer? https://www.google.com/search?q=Lexus+Mint
Driver
PANTUM https://global.pantum.com > support > download > dri... Home Service&Support Driver/File Download Driver ... printer. Product Series. Product Name. You may need. Pantum P2500 Windows Driver. Version: V2.6.30.
PANTUM M7100DW Printer Driver Download
trikprinter.com https://www.trikprinter.com > PANTUM Apr 8, 2017 - Install Driver For Printer. Install Print Driver For Windows : Download the file. select the location of the file that is already stored. Double ...
Drivers for printers Pantum M6700 / M6800 / M7100 / ...
DriverFresh.com https://driverfresh.com > DF.com > Printers and MFPs Drivers for printers Pantum M6700 / M6800 / M7100 / M7200-series for Windows 11 - XP (32/64-bit), Mac OS X 12 - 10.5, Linux Ubuntu 20.04 - 12.04 in English.
how do I publish a printer [duplicate]
Ask Ubuntu https://askubuntu.com > questions > how-do-i-publish-... Jan 5, 2013 ยท 1 answer Open the dash and type Printers, then click on the "Printers" icon. That will open up a window that will probably have a list of printers. What is CUPS server and how to share a printer ... 3 answers Oct 28, 2011 HPLIP or CUPS cannot Find Network Printers? 5 answers Jan 25, 2013 More results from askubuntu.com
Deploying Printers to Domain Users and Computers with ...
Windows OS Hub https://woshub.com > Group Policies Nov 8, 2022 - You can publish your shared printers in Active Directory. To do this, enable the List in the Directory option in the printer settings on the ...
Use Group Policy settings to control printers
Microsoft Learn https://learn.microsoft.com > ... > Windows Server Feb 23, 2023 - Describes the policies specific to managing printers and how to enable or disable printer management by using the Local Group Policy Editor. ..
8/13/2023 11:58:46 PM • Lexmark Office... • Answered on Aug 13, 2023
Need drivers for Lexmark 4431
  1. Visit the Lexmark Support Website: Go to the official Lexmark website (www.lexmark.com) and navigate to the "Support" or "Downloads" section.
  2. Enter Printer Model: In the search or product support area, type "Lexmark 4431" or the full printer model number (e.g., "Lexmark 4431-001") and hit Enter or click the search button.
8/6/2023 7:03:20 AM • Lexmark Office... • Answered on Aug 06, 2023
NEED CD FOR X7350 ALL IN ONE INKJET PRINTER LEXMARK
https://www.lexmark.com/en_us/printer/3233/Lexmark-X7350 Go to "Drivers and downloads link" and download them to your computer
3/22/2023 10:47:25 PM • Lexmark Office... • Answered on Mar 22, 2023
Lexmark cs 410dn EN E4 16 error
The "E4 16" error message on a Lexmark CS410dn printer indicates that there is a problem with the printer's toner cartridge. This can be caused by a variety of issues, such as:
  1. The toner cartridge is not properly installed in the printer.
  2. The toner cartridge is not compatible with the printer.
  3. The toner cartridge has reached the end of its useful life and needs to be replaced.
  4. The printer's firmware is out of date and needs to be updated.
To resolve the issue, you should try the following steps:
  1. Turn off the printer and unplug it from the power outlet.
  2. Open the printer's front cover and ensure the toner cartridge is properly installed.
  3. Clean the electrical contacts on the toner cartridge and the printer with a dry, lint-free cloth.
  4. Reinstall the toner cartridge in the printer, being careful to align it properly.
  5. Turn on the printer and check if the error message is cleared.
If the error message persists, you may need to check the compatibility of the toner cartridge with your printer model, and the age of the cartridge. If the cartridge is old, you might need to replace it with a new one. Updating the firmware of the printer can also solve the problem, check the Lexmark website for update on the same. In case the problem persists after trying all the above troubleshoot, please contact Lexmark support for further assistance.
1/10/2023 7:18:15 PM • Lexmark Office... • Answered on Jan 10, 2023
Lexmark c935 error video making
If you have replaced the engine board on your Lexmark C935 printer and are still experiencing an error 905.01, there could be a few other possible issues that may be causing the problem. Here are a few things you can try to troubleshoot the issue:
  1. Check the printer's firmware: Make sure the printer's firmware is up to date. If the firmware is out of date, it can cause errors like 905.01. You can check for updates on the Lexmark website or by contacting Lexmark customer support.
  2. Check for any visible issues: Inspect the printer and its components for any visible issues that may be causing the error. This can include debris or foreign objects that may have gotten stuck in the printer, or damage to the printer or its components.
  3. Check for other issues: If you have checked the firmware and there are no visible issues with the printer, it is possible that there is another issue causing the error. You may need to have the printer serviced by a professional to diagnose and fix the problem.
I hope this information is helpful. If you have any further questions or need additional assistance, please don't hesitate to ask.
12/26/2022 1:01:55 AM • Lexmark Office... • Answered on Dec 26, 2022
2answers
Unable to load lexmark 2300 series to my new laptop w/vista
You should be able to download a Vista driver for the 2300 series from http://downloads.lexmark.com/perl/downloads/downloads.cgi
11/24/2022 2:00:56 AM • Lexmark Office... • Answered on Nov 24, 2022
Lexmark MS811N Printing only blank pages
Hi, Please remove the toner/ink cartridge out and shake it 4 or 5 times before placing it back into your printer and testing a few prints. Lexmark also recommends checking for packing material on the imaging unit. Thank you.
10/27/2022 7:22:53 PM • Lexmark Office... • Answered on Oct 27, 2022
I need a user guide for Lexmark x4270 All-In-One Inkjet Printer, Driver for Windows 10, and software that was included with purchase
You are going have to find a retailer that has what your looking for Lexmark constantly updates their printers so most items are no longer available, if there is a computer company close by check with them or check either Amazon or Ebay.
9/13/2022 7:10:01 PM • Lexmark Office... • Answered on Sep 13, 2022
Lexmark IBM TYPEWRITER 6747 will not work after power on. The lights go on but don't stay on,
Check the power supply for bad capacitors or take it in for service. https://www.google.com/search?q=Lexmark+6747 ..
8/3/2022 8:33:51 PM • Lexmark Office... • Answered on Aug 03, 2022
I need a ethernet cord for a Lexmark x1240 all in one printer
printer uses USB A to USB B Printer Cable readily available on line less than $10.00
2/26/2022 9:30:28 PM • Lexmark Office... • Answered on Feb 26, 2022
Lexmark X656de Multifunction Monochrome Laser Printer/Copier/Fax/Scanner w/ Duplexing Logo
1 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lexmark Office Equipment & Supplies
Most Popular Question
got lexmar x656de when try scan copy
  • Office Equipment & Supplies
