20 Most Recent
Samsung XE303C12-H01US CHROMEBOOK 11.6" WXGA HD LED LCD Matte Questions & Answers
Pc performance is poor
A slow internet connection could be caused by any number of reasons.It may be connection or Traffic problem.To increase your internet speed use the following tips given below:
1.Clear cookies from your Browser.
2.Delete unwanted files.
3.PC Optimization:
It is important to clean your PC regularly.It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk management.
4.If you are using DSL Connection over your Landline, make sure that you have high quality filters in place to get optimus signal speed.
5.Upgrade your modem.
6.Use updated Browser.
7.Consult with your Internet service provider to ensure that your modem is configured correctly.
8.Replace your telephone modem with a fast-access connection such as wave,ISDN,DSL,Satellite,a cable modem.
9.Tweak your router settings.
10.Install Antivirus Software.
11.Reduce your Bandwidth overhead.
Still your internet speed is slow then, Contact your ISP and get latest speed plan from them.It's better way to increase internet speed.
After completing this steps, you can check your internet speed whether increase or not using this site
ScanmySpeed.com
12/10/2014 2:46:21 PM •
Samsung...
Answered
on Dec 10, 2014
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
My printer spoler is not working
Hi g k,Have you tried restarting the print spooler from services?Start the Print Spooler service from the Services console
- Click Start, click Run, type services.msc, and then click OK.
- Right-click the Print Spooler service, and then click Stop.
- Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
- Click Start, click Run, type cmd, and then click OK.
- Type the following commands at the command prompt:
net stop spooler
net start spooler
exit
Note Press ENTER after each command line.
Hope this helps, and please rate:)Gary
