20 Most Recent Kenwood KDC-MP145 Car CD/ MP3 Player Questions & Answers
0answers
Remove kenwood kdc-mp145 from 1998 Corolla
Step 1:
The radio is secured to the frame of the vehicles dash, with screws located behind the plastic dash panel (surrounding the radio).This plastic dash panel unsnaps from the body of the vehicles dash.
Step 2:
The bottom of the plastic dash panel, just below the bottom of the radio, can be lifted up. Look up from the below the radio and you will notice rectangular openings or insertion points where a flat tool can be inserted to pry out the bottom of the plastic dash panel. With a flat head screwdriver or other flat object, pry out the bottom of the plastic dash panel.
Step 3:
Once the bottom edge of the plastic dash panel has been pulled out, the sides of the plastic dash panel will begin to separate from the body of the vehicles dash. You will now be able to put your fingers into the openings on the sides of the plastic dash panel. Gently pull the plastic dash panel until it unsnaps from the body of the vehicle's dash.
Step 4:
Once all the clips on the plastic dash panel have been unsnapped, the dash can be pulled out. The top of the plastic dash panel will have wires attached to the clock, hazard and defrost switches. You do NOT need to unplug the connectors plugged into them.Move the plastic dash panel up and set it on top of the body of the dash.
Step 5:
The radio is held in with four (4) phillips screws / 8 mm bolts.Remove the screw/bolts. Pull the radio forward.Unplug the antenna cable, and 2 white connectors from the rear of the radio.
Step 6:
If installing a different radio to your Corolla, buy a "snap on" adapter loom which eliminates the need for cutting any wires (Toyota --> New radio brand), from your local auto accessory store.GOOD LUCK !!!
2/2/2013 7:34:16 AM • Kenwood... • Answered on Feb 02, 2013
0answers
Word 'protect'
Please see my tip at http://www.fixya.com/support/r9389300-stereo_says_protect_or_clicks_off_when . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year info.
1/1/2012 2:49:20 PM • Kenwood... • Answered on Jan 01, 2012
2answers
My friend has a kenwood cd player in her spyder,
She may have a bad alternator or voltage regulator. You might want to have them checked out. If you have a multimeter, check the voltage going to the radio when it is turned up.
10/13/2011 4:52:55 PM • Kenwood... • Answered on Oct 13, 2011
Im hooking up subs but
The remote wire is the blue/white one. You can get the wire diagram on the link below page 15.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/113/113MP145.PDF
4/3/2011 12:26:42 AM • Kenwood... • Answered on Apr 03, 2011
I change my kenwood kdc-mp145
make sure you have no shorted speakers or speaker wires. make sure you have no bare spots on your speaker wires. if you can, check to make sure no speakers or speaker wires are shorted to ground. If all checks fine, try pressing your reset switch.
3/24/2011 11:25:47 PM • Kenwood... • Answered on Mar 24, 2011
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
I have 2 mtx 12"woofers (8ohms each wired parallel to get to 4ohms) which Kenwood amp would be best to use: kac-7252 or kac-9104d?
The Kenwood KAC-7252 and KAC-9104D are both great amps, but they have different strengths and weaknesses. The KAC-7252 is a 5-channel amp that can output 75 watts per channel at 4 ohms. It also has a built-in crossover and time alignment, which can be helpful for getting the most out of your woofers. The KAC-9104D is a 4-channel amp that can output 100 watts per channel at 4 ohms. It also has a built-in subwoofer output, which can be used to power a separate subwoofer. If you are looking for an amp that can power all of your speakers, the KAC-7252 is a great option. It is also a good choice if you want an amp with built-in crossover and time alignment. However, if you are looking for an amp that can power a subwoofer, the KAC-9104D is a better choice. It is also a good choice if you want an amp with more power output. Ultimately, the best amp for you will depend on your specific needs and budget. If you are not sure which amp is right for you, it is always a good idea to consult with a professional car audio installer. Here is a more detailed comparison of the two amps: Kenwood KAC-7252
  • 5-channel amp
  • 75 watts per channel at 4 ohms
  • Built-in crossover and time alignment
  • MSRP: $399
Kenwood KAC-9104D
  • 4-channel amp
  • 100 watts per channel at 4 ohms
  • Built-in subwoofer output
  • MSRP: $499
I hope this helps!
12/13/2023 2:44:37 PM • Kenwood Car... • Answered on Dec 13, 2023
3answers
- Kenwood KDC-X396 the Brown mute wire gets connected to what to get the phone to work through it
whatever makes it mute from whatever it is you are in
12/5/2023 7:21:12 AM • Kenwood Car... • Answered on Dec 05, 2023
MANUAL for kenwood dpx-6200m
12/5/2023 6:53:47 AM • Kenwood Car... • Answered on Dec 05, 2023
Kenwood KDC-MP145 Car CD/ MP3 Player Logo
16 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
change kenwood kdc mp145
  • Car Audio & Video
