20 Most Recent HP Pavilion dv6-1050us Notebook Questions & Answers
How to download webcam driver again
It should not need a driver, best thing would be to check HP's website for a driver.
10/21/2012 12:24:37 AM • HP Pavilion... • Answered on Oct 21, 2012
Henches problem in hp pevilion dv6
Chandanipraj,1) Hinges example,http://www.ebay.com/itm/New-LCD-CCFL-Screen-Hinge-Set-Left-Right-for-Hp-Pavilion-DV6-15-6-Series-USA-/261104644529?pt=US_Laptop_Screens_LCD_Panels&hash=item3ccb0cb1b12) HP Support > Pavilion dv6-1050us Notebook PC > Main Supoort page,http://h10025.www1.hp.com/ewfrf/wc/product?product=3860586&lc=en&cc=us&dlc=en&lang=en&cc=usManuals > Click on -HP Pavilion dv6 Entertainment PC - Maintenance and Service GuideIt's a Service Manual,Pictorial guide in replacing the LCD screen, and also replacing Hinges,http://www.insidemylaptop.com/replace-broken-screen-hp-pavilion-dv6-laptop/Just to add;http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/For additional questions please post in a Comment.Regards,joecoolvette(Hi from the USA)
10/19/2012 2:15:31 AM • HP Pavilion... • Answered on Oct 19, 2012
My laptop is Hp. my hard disk has some bad sectors and this is making my operaating system to boot and work very slowly. I use both Linux and windows how do I repair the hard disk and remmove th bad s
bad sectors depending on what has caused it can be increadibly hard if not impossible to rid yourself of them. try opening start and searching for disk defrag. set it for as deep a scan as you can. if you can get it to do it before you boot into windows to allow it to shift and sort booting data and un accessible data in windows. before you let it go also click on learn more about disk defrag and click on the bottom link in the help manual which shows you how to make sure the scanner will find and fix bad sectors . second would be to rid yourself of any and all unwanted files with disk cleanup and manually finding and eliminating programs you dont use especially the HP standard stuff they so dearly love to burden your system up with. thirdly would be finding a good optimisation program. i use TuneUp utilities which to me seems to make it run better. 4th would be replace your hard drive with a solid state hard drive and start clean again with fresh installations. use an external drive mounter to transfer all files you require and shove the old drive in the back of a filing case as a backup. if you use option 4 if you have a secondary hard drive swap page filing to that one to reduce wear. after option 4 if it is still slow you are likely looking at RAM or a faster laptop altogether because one solid state drive will give it a kick up the back end so much you will believe its a whole new beast. and i have 2.for your linux side... i doubt you can do a lot to improve on it as it already is at its bare bones performance peak except for increasing its drive size.
9/17/2012 12:38:53 PM • HP Pavilion... • Answered on Sep 17, 2012
My problems is driver ethernet conroller
You can download the LAN and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -http://welcome.hp.com/country/au/en/cs/support.html
5/28/2012 11:11:01 AM • HP Pavilion... • Answered on May 28, 2012
Download bluetooth driver for HP pavilion dv6
You can download the bluetooth and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -http://welcome.hp.com/country/au/en/cs/support.html
3/19/2012 6:55:30 AM • HP Pavilion... • Answered on Mar 19, 2012
How do I replace the screen on an hp pavilion dv6
Check the following link for service manual for your Laptop:
http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf
Refer to Page: 81 (89 of 176)
7/27/2010 2:11:33 PM • HP Pavilion... • Answered on Jul 27, 2010
I have email error 99999
delete and reinstall your email software.
6/25/2023 8:52:09 PM • HP Pavilion... • Answered on Jun 25, 2023
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
11/30/2022 7:10:30 AM • HP Pavilion... • Answered on Nov 30, 2022
How do i get mywindows keyboard to work
desktop or laptop. ? external Keyboard or internal
6/9/2022 10:54:32 AM • HP Pavilion... • Answered on Jun 09, 2022
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
6/2/2022 6:19:00 PM • HP Pavilion... • Answered on Jun 02, 2022
Hp pavilion entertainment pc 17 sd ms pro mmc xd
HP.COM << go there. And ask a real question ,you did not.
5/25/2022 11:36:13 AM • HP Pavilion... • Answered on May 25, 2022
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate. this is no secret,gee millions sold. A6Y530A the partsurfer shows true model, and fails this is the only post here ever asking for reverse code lookups on models fake, and is not easy in vast cases I guess you have no such PC, (look like) so why ask this>? what prompted this quest>? not told why not ask seller for photos of it if this is a pre sales question , is it>? google and bing and HP all show that model # is BOGUS so go back to your sell and ask the we can not guess PCs ever. HP product ID# is best on the service tag for SURE. where did you see this number, not told. or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits. you posted to HP forum, (not real) Hp.com is real
5/2/2022 12:59:02 PM • HP Pavilion... • Answered on May 02, 2022
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what? symptoms matter most, for sure in a LAPTOP IS IT the word Pavilion is on laptops and desktop, dig? G mean zero , the service tag does not just say "G" sorry. easy peasy lemon squeezy HP.com complex URL no? go there tell them your model # or better the service tag code ! . then magically HP puts you on YOUR service support page and all manuals and all driver before your eyes. amazing no? NO told at all or of a laptop or desktop or what./? you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not. there are over 100 PC called G series, and vast years. some PCs by them G1 to 7 are generations, like HP Pavilion g6-1029tx Notebook. if you can find the service tag the product ID # is what matters most this code includes (real model, version , options and country sold) see this, older PCs by them had this. see that , all matters but do not post SN/ or service codes in public. mine: procuct code (nnnnnnABA#) https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG I will guess it is 17" laptop, here is the mess just that 1 sized once you see this you know that G series means not MUCH> https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
5/2/2022 12:17:49 PM • HP Pavilion... • Answered on May 02, 2022
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP. 40 years of PCs ,10000 + models nobody can guess ever. but I do have the answer, in pure generic form. did you buy the PC like that used and bad Wifi. ?
  1. the wifi card is missing, as was super common 10+ years ago.
  2. someone put in the wrong card, not from HP list
  3. HP blacklists (bios blocks) none HP cards (wifi)
  4. the card needs a driver to work if not it is dead or 1/2 dead.
  5. the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
  6. The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
5/2/2022 11:38:43 AM • HP Pavilion... • Answered on May 02, 2022
Fix pdf handler
today there are many PDF , Viewers not juts Adobe ! google finds them like this. https://www.google.com/search?q=pdf%20viewers
5/2/2022 11:25:45 AM • HP Pavilion... • Answered on May 02, 2022
How reinstall bios on a HP dv9000
bad news now your bricked it just like miillions did google bios update bricked my PC and cry. why are you here and not at HP.com only they can recover bios. they changed the rules now 10 time. so only they know this, and are pain to deal with. UEFI is the enemy here, new rule and regressive as can be. in fact all new PCs can not be regressed, and some old now they even delete the 20 version of bios there, to force that. not saying they did that to your PC, but keep that in your head on all HP PC. the last bios upgrade stated, no going back. the Cntrl_+B might work , the flashback bios trick\ in your manual if you read it.
5/1/2022 4:52:54 PM • HP Pavilion... • Answered on May 01, 2022
How do i remove the tuvaro virus ?
nobody can we erase all and reload the OS fresh. did not say you can not try but that 99 out 100 will fail.
5/1/2022 4:42:46 PM • HP Pavilion... • Answered on May 01, 2022
How do i diagnose/test and repair my laptop
100% dead black screen no text or HP SPLASH screen now. The problem is hardware where we buy hardware for free, less than at deity level or a thief. you tell me.... no PC told at all not one tiny clue of 1000s of HP models for 4decades are we to guess models and lie to you? now the GENERIC answer USA PCs only sorry I do not do others. fans dead? no beeps> codes no Caps lock key blink codes. no text errors.? 1: does PC run BIOS pages if huge now shorted old relic battery is removed ,yes bingo 1. 2: is the RTC coin cell dead, ,Bingo 2. a $1 uSD ,USA cost. here. 3: the pre 2010 all have bad CCFL lamps; do this flash light test? https://www.pcdied.com/monitors_and_screens/flash-light-trick.html#flashlighttest if yes, that is a $50 to $100 USD parts repair , labor more. repairs are serial process, as fixing one thing bad ,uncovers the next this is how mans machines work just like that. NO PC told, NO PC told,NO PC told,NO PC told,NO PC told,NO PC told,NO PC told, all I can do is BEG,
5/1/2022 4:34:40 PM • HP Pavilion... • Answered on May 01, 2022
HP Pavilion dv6-1050us Notebook Logo
20 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
laptop hp hard disk some bad sectors
  • Computers & Internet
