learn to post photos here of any failed screen. and we are told are worth 1000 words. they even said that back in 1860, and still is true.learn to post photos here of any failed screen.
You can't post conmments that contain an email address.
No pc told, Pavilion means zero that name is is used on desktops and laptops for ages the HP has diagnostics so run those. HP.com tells how. not told desktop or laptops. just 1 word."Screen" first Pavilion was 1995
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
You might like to Power it off completely by removing the Battery for a few seconds.
If that doesn't help, try booting from your Win7 Installation Disk.
was there a new hardware that was added to your laptop? bluescreens often are caused by hardware.
while the laptop is booting up when you are asked for options on how to start you computer is there an option for start windows using last known configuration? if there is try that and if it still goes into bluescreen you may want to try and recover your laptop using the hp recovery cd or recovery tool. if it still doesn't work most likely you have a bad memory chip.
Dear,
Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
When booting up keep F8 pressed untill you see a screen come up with various things you can do.
Using the updown keys select go back to a setting that last work[ or word ti that effect]
click on that see what happens
come back when you can
