Philips PET702 Portable DVD Player Logo
Posted on Jul 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My philips tv won't store the tv channels. every time I switch the tv back on I have to perform a search to find the available channels and then store them but if I turn the tv off, I lose all the channels and have to search all over again when I put the tv on. I have checked and checked that I am going through the process of storing the channels correctly but to no avail. Any help out there, please?
kj henriksen
Level 2:
Sergeant:
Habit-Forming:
  • Expert 194 Answers
  • Posted on Jul 31, 2017
kj henriksen
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
194
Questions
Helped
37718
Points
504
Open tv menu
run scan on antenna
they should store then
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Feb 20, 2007
SOURCE: dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Anonymous
  • Posted on Mar 16, 2008
SOURCE: DVD playback color
When passing the video signal thru a VCR on the way to the TV, you are activating the DVD's "Macrovision" copy protection.  You need to hook it directly to the TV.
Anonymous
  • Posted on Oct 20, 2008
SOURCE: Phillips TV/VCR combi 14PV400/07
To solve this problem, cancel the wake up alarm !
Anonymous
  • 4 Answers
  • Posted on May 14, 2009
SOURCE: Philips HDRW 720/17 stuck in '':demo'' mode???
Okay. I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Anonymous
  • 11896 Answers
  • Posted on Aug 29, 2009
SOURCE: My Philips 50pf9631d plasma tv turns on then red
Are you getting picture or sound at all? If not, you could have a very common power supply failure. If you get sound or picture, then you may have a faulty capacitor or resistor on one of the system boards
WHAT is this tv digital ?
Dear Friend,
First, search for available air channels by going to you menu and then search for channel setup.
Second: change the option from Cable to Air Channels.
Third: after performing the channels setup you should be able to see free channels trough the air.
Good Luck!
Lg tv losing stored channels when turned off
I purchased an LG43UN7100 just before Christmas 2020. It has used the same aerial connections (ports/cabling) previously used by both Samsung and Philips televisions, which worked perfectly. After twelve days of use, I've now retuned it 4 times and have even followed advice to disable the Quickstart Plus and reset back to initial settings. From an internet search I suspect that this is a common 'feature' of LG televisions :(
Philips tv won't hold programmes
try replacing channel up and down tact switch..this probably helps..
How can I get my Philips TS3259C1 to turn on with AV1 as the channel?
You have to enter its service mode option to make it. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Cant get cable tv
Hello
First connect the cable to its cable input socket at rear.
Turn the tV On and enter its Menu option window. Press UP or DN button on the remote control to select 'Cable'. Selecte EZ scan [channel search]. The TV must scan for all available channels, and will stop after all the channels has been stored in its memory. You have to wait till the search function stops; no other functions with remote cannot be done, and the set will not respond any external command, either by remote control or by its front panel control, except the mains power ON/OFF switch will work. OK.
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
I want to retune Philips 32PW9576 / 05E
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
