1998 Oldsmobile Intrigue Logo
Posted on Aug 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The cart wont click over dont know anything bout cars so i need to find out if my starter or my alternator went out and sure my battery i need a new one because the car used to click over till we hooked up jump cables then made a weird noise and now it wont start over
Jason Johnson
Level 3:
President:
  • Oldsmobile Master 1,619 Answers
  • Posted on Aug 02, 2011
Jason Johnson
Oldsmobile Master
Level 3:
President:
Answers
1619
Questions
0
Helped
441487
Points
3913
First if the jumper cables were hooked up backwards you could have killed your battery, which was probably dead to begin with. Get a new one then try and start. If it doesnt look more into the ignition switch than the starter. Alternator has nothing to do with starting, it could be bad and not charging the battery but will not cause your car not to start.
3answers
Car wont turn over and making a humming noise when key is in on position. when i try to start it the car makes a clicking sound.
the alternator isn't charging battery that would account for loss of power and also clicking when try to start , try a jump start if it starts then you know its the battery so with engine running check the alternator charge rate with a voltmeter across the battery terminals anything below 13 volts then check the alternator belt is tight enough , good condition etc , then recheck charge rate if still low fit new alternator
2answers
93 Toyota Pickup, new starter,Battery,alternator, wont start
Check connections in wiring. Could be a ground fault
Battery will not charge, first time its ever did this. rebuilt alternator new battery and new starter not to sure if new starter has anything to do with battery chargin but replaced it anyway, has good...
A bad voltage regulator could cause the problem. Assuming the alternator is working correctly. Jump the vehicle with the battery disconnected and then disconnect the jumper cables. If the vehicle dies your voltage regulator or Alternator are bad, some vehicle have separate regulators from the alternator, if it continues to run the alternator is good but the voltage regulator is probably the cause.
2helpful
2answers
1988 Ford Ranger truck, new battery and new alternator but car won't start, it just clicks?
the clicks are a signature of a bad battery, since your is new, it probally is not bad, i would try to jump the car with cables, even though your battery is new, you dont know how long is sat ont he shelf before you took it home, may be weak, 1 good jump to get the motor going and the alternator will charge it right up so wont have to so it again....
the only other thing is the starting system left to look at if that dont work is the starter, try banging on it a little with a hammer, not to hard though, as someone turns the key, this will sometime free up a locked up solinoid.
Good Luck
Car wont start same click new alternator and battery
take to a local rebuilder most likely starter common honda problem
3helpful
2answers
Son has a 2005 Nisssan Altima and Hear clicking sound.
Most likely the alternator,chech for loose connections at the alternator first, if you have access to a voltmeter you can easily check this.Get the car started and place the leads to the battery terminals,if the alternator is good you should get about 14.8 v at idle and it will go as high as 15.5v to 16v as you rev the engine up.Anything between 12v and 14v at idle indicates a weak or not operating alternator.If you get a good reading run it for a bit and then see if it will start again,if it wont start check the battery cables(especially the negative) for corrosion or loose connections,look for cuts or tears in the insulation or a bulge in the cable wich will indicate corrosion under the insulation.If everything else checks out good and it still won't start then you'll need to look towards the starter.
2answers
2005 Honda Civic wont start. Just makes a clicking sound
This sounds like a starter problem, does it click when you hit the key? are the battery cables ok, not corroded?
Cutlass supreme wont start
It could possibly be the starter, but before you get that far make sure the Battery cables are connected very tight. If loose the car won't start or do anything. Also make sure the battery cable is grounded.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
