SOURCE: frigidaire electrolux gallery series
stoveboy,
I know you probably have the problem fixed by now, but I had the same problem with my frigidaire range just the other day. Loud popping sound, range/clock controls do not work. Stovetop still works great.
I took the back off the stove and got to the circuit board. Unplug the connector and the five spade connector wires. Once you do that, remove the 4 screws holding the entire assembly in place. The circuit board(s) are held in the housing with retaining clips on the housing. Use a small screwdriver or similar to pull back on each clip to pry each side of the board out. Once the board(s) are free, look in between the two circuit boards and you will see the problem. The larger, 20 amp relay is the culprit. It blew traces off of both boards making it almost impossible to repair. Without having a schematic to go by, I went ahead and decided to just replace w/ new boards as opposed to trying to solder the traces. I have not checked on prices, but brief web searches didn't return any results. The board part # is SF5301-S7509-N
SOURCE: Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
SOURCE: The lower burner in the oven of my Frigidaire
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
SOURCE: How do I raise the cooktop on my Frigidaire
If you raise up the top you will break the tubing going to the burners. You must remove the screws on each sealed burner before raising the top. Look closely and you will see the screws. They will be hard as heck to come out. If a stove is real old and I cannot get the screws out I dremmel the screw heads out and drill out the screws. I do a repair and then pop rivet the burners back on. If I have to go back in there it is nothing to drill out a pop rivet. That is how I do it on real old stoves. You may figure out a better way. You have to get those burners loose or you will break those lines below the top.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks! Great advice. Did just what I needed to do."
SOURCE: Frigidaire Gallery Range (New). When plugged
When it doesn't heat up,
We have a Frigidaire Range model PLEF398CCC and, as many others here
have mentioned, we saw the puff of smoke and the oven nor the front left
burner works. The repairman has to replace a EOC on the back of the
control panel and another one in the back on the bottom. The total cost
for parts alone is $438 then add in the service call cost. THIS IS THE
SECOND TIME we've had an EOC go bad for big bucks. The unit is about 5
years old. We're thinking of filling the landfill with it.
Use this for troublshooting:
(home-electrical.suite101.com/article.cfm/troubleshooting_an_electric_range)
another testimony to help,
Had the same problem. This solved it for me:
(lazerangle.com/sanna/index.php?option=com_content&view=section&layout=blog&id=6&Itemid=63.).
Take care.
