20 Most Recent Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Questions & Answers
here ya go as far as getting the part.
https://www.repairclinic.com/Shop-For-Parts/-x676c6568313634326673/Gleh1642fs-Parts
they too have a very helpful chat or 800 team to answer questions many times when you select the part there is a install section.
Hope this helps. I know as I had this problem.
If you need directions I can help but tis a bit detailed.
maybe a youtube video on it helps to look when you know what part # your installing and what it's called
Have a good evening..
Frigidaire... | Answered on Jan 09, 2018
I have a GLEH16242 Frigidaire/Electrolux stacking washer/dryer. The main bearing went out on the washer. I did the expensive fix of replacing the outer drum/bearing assembly in hope of nothing going wrong. Everything went together well, but now it won't go into high speed spin. It does if I have no clothes in it, but as soon as I introduce clothes it only does the 'medium spin' but never advances to the high. I've changed shocks, confirmed the door switch is working properly and double checked level. Even placed it on a big thick sheet of plywood in hops of stabilizing it more. It does have a wobble to it when it starts spinning, but when it kicks into medium spin, is smooths out.
Frigidaire... | Answered on Mar 12, 2017
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
Frigidaire... | Answered on Mar 05, 2016
Hello friend, thank you for your inquiry!
I understand that your Frigidaire washer is not spinning I would suggest checking the drain hose to assure it is not restricted or too long. If the hose checks out you could have an issue within your belt, pulley, motor, or control.
Since it could be any one of these underlying issues I would recommend having a professional come out to properly diagnose and repair your appliance. -Matt
Frigidaire... | Answered on Sep 05, 2014
Hey Salvador Juarez, I appreciate your post!
I understand that when you try and press the dryness cycle on your Frigidaire laundry center it provides you an error. I would like to ask you some additional questions in order to best assist you. Does it show you a code or beep? If so, how many times does it beep? I look forward to your response. Thank you. -Matt
Frigidaire... | Answered on Aug 05, 2014
Good Morning Joel,
I understand the dryer on your laundry center, model# GLEH1642DS, will not power up, but the door light comes on. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 11, 2014
Good Afternoon Friend,
I understand you want to know how to fix the locking mechanism on your Frigidaire laundry center, model# GLEH1642DS. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to fix the locking mechanism with ease. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 03, 2014
I understand that the washer timer on your Frigidaire laundry center, model# GLEH1642DS, stopped turning and you want to know how you can diagnose this. Typically, this is not be a do it yourself repair, as there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose it and determine what is causing the timer button to not turn. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 01, 2014
I understand that you want to turn the buzzer off of your Frigidaire dryer, model# LGR331SO. With your model dryer, you are not able to turn the buzzer off. I hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 02, 2014
Hello Reese,
I see that you're having a Problem with your Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer. I see that the washer will not work until dryer is turned on and the dryer will not heat. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the appliance is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back on and try to restart it. If you are still having trouble with the washer not working until dryer is turned on and the dryer will not heat. I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Frigidaire... | Answered on Jan 24, 2014
major problem, could be transmission or timer switch cost for repair could be high
Frigidaire... | Answered on Oct 12, 2013
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
121 questions posted
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
washer drum not turn
  • Washing Machines
