One of your op amps is probably gone or there's a bad capacitor somewhere.
Get an oscilloscope and trace the oscillation from the output back towards the input.
When you see clean signal on one side and oscillations on the other side of an op amp, that op amp will need to be replaced OR if you see bulged or leaking capacitors around / connected to that circuit, they will need to be replaced.
Also look for damaged driver transistors between the clean and oscillating signal.
A schematic will be extremely helpful in these situations!
