SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door. Set for cubed ice. Press the button for ice to come out and listen for a loud clunk noise. That is the sound of the solenoid. You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down. Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into. If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work. If solenoid is not working then it will need to be replaced. Let me know what you find.
SOURCE: Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
on a whirlpool side by side i get water from the door but no ice. i put power to both sides of the selinoid and it worked fine. it acts like what ever askes for the water to the ice maker is not working. it will despense ice fine if you put ice in the bin.
SOURCE: Ice dispenser in door will not dispense ice
this could be the:
door switch (usually 2 switches, 1 for the light and 1 for the dispenser)
auger motor itself
the dispenser switch
or the plug near the hinge that connects the door the the refrigerator has a bad connection. this connection is hidden under a plastic hinge cap usually.
SOURCE: icemaker auger
To see how the auger goes back together, go the the Sears parts web site and put in your model number. It will show the parts list and a diagram. You may be able to print it out, Don't remember if there is a print option or not but if you have a screen capture program you could also.
SOURCE: Whirlpool GS6SHAXMB00 ice dispenser not working
remove the ice bin close door and push for ice and hear if the motor working if motor not could be door switch if motor working is the solideo valve
