You need to send the model number kenmore doesn't make anything,the only way to tell who made it is by the model number but anyway if it stalls on you and you go to restart it does it make like a buzz sound if so you have a bad motor,when the motor cools off it starts again,it's not a t-stat or anything because when they fail they won't work again non resettable,most likely will be the motor
SOURCE: Kenmore 80 series dryer
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
SOURCE: kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
SOURCE: Kenmore 80 Series Electric Clothes Dryer-Won't Start
check the door switch , a little arm that clicks in when the door is closed. check to see if it clicks or if its even still there.
Phil
SOURCE: I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
The
Kenmore 80 Series of dryers are consumer grade dryers for home use. As
with most home appliances, the Kenmore 80 series dryers will
occasionally not work as intended. If a problem occurs with your dryer,
however, you do not necessarily need it serviced by a technician. You
can attempt to troubleshoot and fix any problems with your dryer before
contacting a technician.
