It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on
cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
I hadn't cleaned my filter for mad long and i took the filter out and it was straight black as ****. Clean that **** regularly or maybe you'll get some type of mold build up in your lungs and die.
