Question about Danby DDR2504 Dehumidifier
As I tell most folks who complain about the problem you're having
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter. To remove the filter on your model it will either have a pullout tab on
the right side of the unit, behind the louvers on the front. Or remove the bucket and the filter
frame will be just on the inside top of the opening behind the front louvers.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air
temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Posted on Jun 25, 2011
Please disregard the answer above, It was meant for another questioner. In your case. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. Then plug the unit back in, turn the Master ON/OFF Switch ON and set the controls as you desire. Hopefully, that 15 minute timeout allowed the unit's electronics to reset themselves and reverted back to the original factory settings.
Dec 18, 2012 | Danby DHCC6020 Dehumidifier
Sep 11, 2011 | Danby DDR2504 Dehumidifier
Aug 23, 2011 | Danby DDR7009REE Dehumidifier
Jul 17, 2011 | Danby DDR600R Silhouette Dehumidifier
Jun 08, 2011 | Danby DDR586R Dehumidifier
Jun 07, 2011 | Danby DDR2509EE Dehumidifier
Jun 02, 2011 | Danby Dehumidifiers
Jun 01, 2011 | Danby DDR583R Dehumidifier
May 10, 2011 | Danby DDR2504 Dehumidifier
May 06, 2011 | Danby DDR4007EE Dehumidifier
Jul 22, 2013 | Danby DDR2504 Dehumidifier
Jul 06, 2013 | Danby DDR2504 Dehumidifier
5,199 people viewed this question
