Hi i am nitesh
i have Samsung n150 netbook
my problem is my some key not working
means i type UIOPJKLM this are kye not type
i type U but keybored type 4 means numerical number type
pl help me
You have your Num Lock on. Look for the Num Lock key on the top right of the keyboard and press it. That will remove the Number Lock and the letters will type as normal.
Some dust or liquid must have entered or dropped on the keyboard. If it is just dust try using a compressed-air spray canister to blow in the space around the key.
If that does not work you can use a thin knife or flat screwdriver to pry the keys off. Do that with the 3 key first as the space bar is more difficult to put back in - there are a couple of springs that have to be fitted just right. Clean away any dirt and push the key in place.
If it is a liquid then you must open the entire keyboard panel and clean it from the inside. If you have the confidence and skill to do that you can try searching samsung support about how to do that. It is not that difficult if you follow the instructions carefully, but if you yank the flat cable connector off it may be difficult for you to snap it back in.Otherwise ask for professional repair.
There should be a way to reduce the sensitivity of your touch pad. Check your manual. There might be an application in your control panel. Check there too.
