Common problem. The water admitance valve is stuck in the bore. The valve lets in more water when pressure drops and when wand is closed the pressure builds and the incoming water is blocked. Remove the valve spool and clean the bore with crocus cloth on a dowel rod. Replace the O Rings and lube with plumber's grease and re-assemble. Often you can buy an O Ring kit for the unit. Deposits build up and stick the valve spool at the high pressure end. The valve is usually crossways to the shaft and right where the water input is connected.
