I hope I can help!
This should be what you are looking for. This page would be the best place to find drivers for that particular model as it is the actual manufacturer's page. Upon further investigation, it seems that Windows 7 already has the necessary drivers for that printer. Link. According to HP, all you need to do is:
1. Power on Printer
2. Then plug it into your pc via USB
3. Wait for it to install (you should get a message from your taskbar when it is done)
4. Print something to make sure it works
Instructions from HP's Site
That really should be all that you have to do. If HP does not have drivers listed in their support section (as they do not), then you are probably not going to find them anywhere else, and must already be included in you Windows 7 Installation. If for some reason this does not work, you might try windows update, and then try installing again. If you need any instructions in this regard, or anything else in this post, just post a comment and I will try to help you out!
I hope this helps!
