Why didn't you buy the overload and relay?i would get that 3 in 1 out of there,order the correct parts,most likely if the condenser fan motor failed the compressor was running to hot and cooked the overload and relay but this has a mother board in it that runs almost everything on this machine,you can't remove the cap or other parts so if i were you i would order the correct parts,put that cap back in and order a new condenser fan motor,if this machine is like 8 to 10 years and you never updated the mother board this also could be your problem,look at the mother board if it doesn't have all 7 of the relays in it it's not the newest board,also have you noticed the evap fan in the freezer maybe revving up or changing speeds that's another way to tell if you have a bad board if you noticed the fans speeding up or slowing down,here's a video hope this helps but get that 3in1 out of there and order the correct parts
https://www.youtube.com/watch?v=7m2XWHqr-n4
go here put your full model number in and you can see all the parts in your machinehttps://www.searspartsdirect.com/model-n...
SOURCE: GSH25KGRBB ge fridge
THE P.C.BOARD. UNPLUG FOR AFEW MINUTES THEN TRY IT. IF NOTHING, REPLACE BOARD.
SOURCE: Wiring hard start capacitor in GE refrig
I would go back to person who gave that advice because just the right touch on that capacitor and YOU my friend will be in the hospital. If this is helpful, please post as such. TY
SOURCE: Maytag MZD2766GEW No Cooling
I replaced all the factory components with a supco 4 in 1. This fridge has a run relay and you must use the the supco part that has a the run cap included or use the Supco part wired to use your original. I did use my original overload too. I should detect compreesor heat much better. Doesn`t hurt a thing to use two overload devices. Some techs do not recommend start kits like Supco but my fridge runs just fine. It could save a unit that you would have to replace. I would not use one on a newer fridge that is still in warranty.
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
SOURCE: Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
