Dryers Logo
Posted on Jun 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas dryer will not stay lit - Whirlpool Dryers
Anonymous
Level 3:
Brigadier General:
  • Master 3,301 Answers
  • Posted on Jun 12, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3301
Questions
0
Helped
1014166
Points
10058
1helpful
White westinghouse gas dryer
Probably the pilot valve is faulty. If the pilot stays lit the unit will still work properly, but should be repaired soon.
Gas dryer wont stay lit and I already tried replaceing the gas valve coils.
Staying lit is a control issue, consider getting a qualified gas appliance guy to look at it, as home explosion is the next exposure.....
Maytag neptune dryer will not stay lit. It starts up, lights, stays lit for about 1 minute and then goes out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 • Dryers
2answers
The heat sensor will need to be replaced
Apr 03, 2010 • Dryers
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
My dryer doesn't stay lit
This could be a operating thermostat/thermister if it comes back on again and continues that cycle. If it stays off a long time then it could be the coils on the gas valve. Eric
1helpful
Is there a pilot lite that has to be lit on a roper gas dryer
IF YOUR DRYER IS GAS , IT SOUNDS LIKE THE THERMOCOUPLE HAS WENT BAD IF YOU TRY TO LIGHT THE PILOT AND IT WON'T STAY LIT THIS IS YOUR PROBLEM
Aug 10, 2009 • Dryers
1helpful
Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Oct 08, 2007 • Dryers
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
