Computers & Internet Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Print spooler error in windows xp sp2 & sp3 - Computers & Internet
Anonymous
Level 3:
  • Master 313 Answers
  • Posted on May 12, 2011
Anonymous
Master
Level 3:
Answers
313
Questions
0
Helped
95903
Points
1022
Click on Start -> Run ->Type: services.msc and click OK, this will bring the services window up. Scroll down to print spooler, turn on then double click on the Print Spooler Service and set start up type to Automatic, then click OK. Restart PC. Now, you have to reinstall the software (if you can't find it, please tell me your model so I can search it for you) If this won't work, completely uninstall all the software and again, reinstall it. Click on Start -> Run ->Type: Control Panel in the dialog box and click OK. Click on add remove programs and uninstall the software for the printer.
Then check Under the Printer and Fax to see if it was uninstalled. If not then just delete it. Printer and Fax is located in Control Panel. Once it's completely uninstalled you have to reinstall the software for the printer.
Error bigpipe win xp professional sp2
This is due to a security flaw in SP2. You will need to download SP3 update from Microsoft!
IF you go to Microsoft XP SP3 Manual Update, follow this link and download the update then run it. This will correct the issue.
I also suggest that turn on automatic updates. Although XP is no longer supported by Microsoft you will still get all the old updates.
Fp 410 pos printer printing strange characters new instalation of windows xp sp2 even on test page used original fujitsu drivers
update to SP3 and see how you get on, if you have no luck after updating to SP3 try downloading the printer drivers from the manufacturers website
2answers
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
The print spooler is not running
Go to run. Type in services.msc. Look for print spooler and click it. You should be able to start it.
5helpful
3answers
I want to install xp sp3, but not sure.some people are saying its not worth it, or you get alot of problems. should i stick with sp2 or get updated to sp3? please help. thanks
sp3 is an essential download,yes you should get it .its bugs have been worked out.its also critaical to keep your pc safe from hackers and such.Shouldnt have a problem with it,but even if u did just uninstall it..
1helpful
2answers
Do I have Windows XP SP2 SP3?I need help please!
your game requirement says the minimum requirement is SP2 but recomemded SP3, your game still runs in SP2
W200 cause a blue screen
First of all: If you install SP2 you don't have to install SP1 over it. It already did. Secondly, don't install SP3, it destroys Windows XP.
Try reinsalling the PC with SP2, install the drivers and do nothing else, see if that helps.
If not, by all means post back here,
Yannick.
Spooler problem in network printing.
Dear user,
if your winxp sp2 is installed pl run sp2 patches again after your problem solved.
Regards,
Ravindra Shah
Grand Canyon Tech
Grand Canyon Tech
