Computers & Internet Logo
Posted on May 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PowerEdge 2850 server beeps as soon as it is turned on - 3-2-1 beeps format. What has failed?
Brian Sullivan
Level 3:
  • Dell Master 27,725 Answers
  • Posted on May 03, 2011
Brian Sullivan
Dell Master
Level 3:
Answers
27725
Questions
Helped
5670361
Points
79191
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Anonymous
Level 2:
New Friend:
  • Expert 53 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
13565
Points
168
Well...Dell doesn't document a 3-2-1 beep code, but the beep codes that do start with 3 all point to the motherboard as the problem. Hope this helps.
Regards,
Matt
How to make a dell 2850 to print on a HP color laser jet CP2025
Download the HP universal driver, plug in printer turn it on. Select the HP universal driver.
URGENT. Dell Poweredge 2850 Mirror 1 Now it is not booting. How to make it boot from Mirrored disk Thanks for any assistance
If you know the two drive that are the OS mirrored drive, remove the failed drive and replace it with the good mirror drive and boot the system. If the drive and the OS is good the system will boot from that drive. You can now mirror this drive with a good disk.
1helpful
My dell server poweredge 2850 sound like jet taking off
This is perfectly normal for this server. It powers on, the fans come on all at once and then, dial back down to a loud whisper. All Dell 1850, 2850, 1950, and 2950 servers do the same thing. It does no harm to the server whatsoever and is a normal part of the initial power up process.
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
1helpful
Can ubuntu be installed on dell poweredge 2850
yes Ubuntu can be installed in Dell poweredge 2850 server
Hi i have a dell poweredge 2850. Orange LED blinking
It sounds like a hard disk has failed or fallen out of sync.
This can be a serious problem if not addressed ASAP.
Call Dell, they have lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis before you call.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
4helpful
Reset Bios Password on a Dell Poweredge 2850
The following information was found here http://www.darklab.rutgers.edu/MERCURY/t15/pe2850dell.html
This should take care of your issue.
Password Jumper Place the jumper on both pins to enable the password. To disable the password, remove the password jumper.
2answers
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
