Question about Dell PowerEdge 2300 Server
Hi i have a dell poweredge 2850. Orange LED blinking
Hi i have a dell poweredge 2850. This morning i have orange led blinking and the following message: bp drive 1. What does it means and how i can it be fix
Thks
Daniel
Posted by dlarocque on
  • Anonymous Mar 27, 2014
    blinking yellow led
Jax Planet
  • 923 Answers
It sounds like a hard disk has failed or fallen out of sync.
This can be a serious problem if not addressed ASAP.
Call Dell, they have lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis before you call.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Posted on Jul 23, 2009
Orange light keeps blinking on my dell poeredge 2600
Orange blinking light means a component failure.
I had a cooling fan failure and this caused the orange light. When there is a failed fan the other fans RPM is increased to compensate. Is the server fan noise excessive?
Aug 21, 2013 | Dell PowerEdge 2600 Server
How to make a dell 2850 to print on a HP color laser jet CP2025
Download the HP universal driver, plug in printer turn it on. Select the HP universal driver.
Jan 22, 2013 | Dell PowerEdge 2850 3.8GHz 2u Server...
Windows server 2008 raid setup on a dell poweredge 2850
2 drives indicates they are RAID 1, which are mirrored. 2 x 36GB = 36GB. This is an industry standard config. If you make any changes you will lose the array making it RAID 0 (no RAID - no longer hot swap), and or the complete loss of OS / data.
Instead make another logical drive for data storage. You need three or four drives to set up as RAID 5, again an industry standard config.
Make sure to back up in all instances. GL
Nov 14, 2012 | Dell PowerEdge 2850 3.8GHz 2u Server...
Orange led blinking
On page 7 and 8 there is a diagram about the different lights.
ftp://ftp.dell.com/Manuals/all-products/esuprt_ser_stor_net/esuprt_poweredge/poweredge-xeo2600_Service%20Manual_en-us.pdf
Feb 10, 2012 | Dell PowerEdge 2600 Server
What could be the problem when you power on Dell Sc 430 Poweredge, you get only a blinking orange color?
these servers are single power supply when that goes you only get a blinking orange light and no beeps.
most other issues will beep code.
I would start there. you can remove and reinstall. but it is probably bad
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
URGENT. Dell Poweredge 2850 Mirror 1 Now it is not booting. How to make it boot from Mirrored disk Thanks for any assistance
If you know the two drive that are the OS mirrored drive, remove the failed drive and replace it with the good mirror drive and boot the system. If the drive and the OS is good the system will boot from that drive. You can now mirror this drive with a good disk.
Sep 18, 2011 | Dell PowerEdge 1800 Server
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
Can ubuntu be installed on dell poweredge 2850
yes Ubuntu can be installed in Dell poweredge 2850 server
Oct 29, 2009 | Dell PowerEdgeTM 2850 (PE2850MIN) Server
Reset Bios Password on a Dell Poweredge 2850
The following information was found here http://www.darklab.rutgers.edu/MERCURY/t15/pe2850dell.html
This should take care of your issue.
Password Jumper Place the jumper on both pins to enable the password. To disable the password, remove the password jumper.
Apr 06, 2009 | Computers & Internet
Dell PowerEdge 2300 Server Logo
4,912 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
