BenQ Joybook A53 Notebook Logo
Posted on Apr 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi : I want to install 3 Gb ram on my A53 , Is that possible ? ( I see this (upgradable to 2 Gb) on benq website !!! ) Please help me fast because i want by that ram tomorow thanks
Anonymous
Level 3:
  • Master 438 Answers
  • Posted on Apr 30, 2011
Anonymous
Master
Level 3:
Answers
438
Questions
0
Helped
79485
Points
1310
Sorry Shervin. If the website says 2 gb RAM then the motherboard is not capable of handling more than 2 gb.
I have checked the socket type. It's a mPGA478MN (foxconn). I am having 2 gb of DDR-II ram already. Now what you suggest for upgrade?
Why do you want to upgrade? Is it slow?
First check for viruses. Also download and run ARO 2011 trial. It will give a report which will show you the errors in you computer.
If you want to correct them, you can consider buying it.
1helpful
My Wifi is not working. My laptop sound is scratchy. I want to upgrade my processor from celeron to core 2 duo which one i should select for cpu upgrade?
Two main things to know before you can attempt a Processor upgrade.
1) What Processor socket is on the motherboard?
2) What motherboard chipset is on the motherboard?
(Northbridge and Southbridge chip. Unless it's a motherboard that supports Intel Core 13, Core i5, Core i7, and Core i9 processors)
According to specifications I found online just now, the BenQ Joybook A53 comes with an,
Intel Core2 Duo T7250 processor,
http://laptops.techfresh.net/benq-joybook-a53/
Scroll down.
(Only 512MB's of DDR2 Sdram (SO-DIMM) ram memory that operates at 667Megahertz?
{ PC2-5300} Yecch! You need at LEAST 1GB of ram memory. (512MB + 512MB = 1GB.
2GB would be best)
http://www.laptop-software.com/benq/benq-joybook-a53-features-and-specifications/
Information on the Intel mobile Core2 Duo T7250 processor,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Core_2_Duo_2
Scroll the page down until in the left column you see T7250. Then read across, and match the headings above.
Uses a Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M
Is your problem directed to a BenQ Joybook A53 Notebook PC, or is it another model?
5answers
I am upgrading to windows 7. How much memory should go with the up grade? at present time I have1028 and512 GB installed. CPU ok for the up grade?
minimum 2GB for smooth use of the pc, but RAM is fairly cheep so I would go for 4GB. The most importet hardware to be fast is your harddrive.
1helpful
2answers
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Where to free download benq a53 lan drivers
Hi, try this link for your drivers: http://www.howtodrivers.com/model510153.html
Hope this helps
1helpful
3answers
I want to upgrade my ram for my pc...atmost to how much i can upgrade and in each slot individually how much capacity of ram it supports ...my motherboard is 915glvg
i would like to inform you that *********** board supports upto 4 gb ram and 2 gb in 2 slots will be the best combination but depends on the OS you are using if its 32 bit XP or Vista it wont accept more than 3 gb so if you wish to use your system in full throttle mode upgrade you r OS to 64 bit XP or Vista and enjoy all 4gb standards that you actually wish to but even 3 gb is like playing with wild fire that will be really too fast processing speed and thrilling performance that you expect.
thanks and regards
kindly rate this solution
5helpful
2answers
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
6helpful
4answers
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
Vgn a170b ram upgrade problem
your ram IC not compatibel or not work well with your laptop
it's recentlly happen
please rate
Top BenQ Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Jean Thiebaux
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
