SOURCE: Setting the time on my iLO DVDR05 Recorder
1 Press Setup to enter the setup menu.
2 Press the up/down keys to select GENERAL, press enter, Use up/down keys to selet clock setting. press enter.
3 Move to the field to be edited using the up/down keys
4 use up/down keys to increase or decrease the value of the field.
5 To exit a field using the right/left keys
6 Press return to exit the clock settings menu.
Select time format from the menu and press the right arrow key. Use the up.down key to pick hour mode(12hr or 24 hr).
Thats the instructions from my manual.
SOURCE: Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
