M&K Sound Mp Series MX-150 Subwoofer Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MX-150 Subwoofer amp went out trying to find a replacement
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on Apr 21, 2011
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1670579
Points
10301
The actual center amplifier went out? Ouch, those cost but I found one for sale. http://robbreport.com/MX150-AV-Control-Center Phone number for contact is on the page.
Regards, Tony
Klipsch Reference R-112SW Subwoofer. Need replacement amp for Klipsch R-112SW. Klipsch has none in stock.
Question edited for a lot more clarity, fix typos and remove all the abbreviations.
Question moved from Televisions to a better category.
These are all the parts suppliers.
https://www.google.com/search?q=106626+spl-120SW+NA+amp+kit
2helpful
How do i connect subwoofer (canton movie 125 mx) to amplifier(onkyo txnr609)? there is one subwoofer output on the amplifier with either L & R(mono) high level input or L & R(mono) low level input...
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
I have an AR s112ps subwoofer. I woofer is blown and i would like to find a replacement woofer. I havent had any luck looking on the net so far. any ideas?
all you need is an 8 ohm subwoofer or a Dual Voice Coil (DVC) 4 ohm subwoofer wired in series that can handle 120 Watts rms. I Went with a Rockford Fosgate Punch P1 P1S812 12-Inch 150-Watt Subwoofer - 8 Ohm
it was only $35 from amazon and is probably nicer quality than the original driver. Good Luck
I have installed a 12" w7 and jl 1000/1 v2 amp. I was useing the bass knob untill i found out on the jl website that its not needed for this set up. I was haveing problems blowing 80 amp fuses so i went...
It is NEVER a good idea to increase the values of fuses . Chances are you have internally damaged your amp. The next time you are faced with this problem you need to find out why your amp is blowing fuses and not keep changing the value of the fuse.
2helpful
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
2helpful
I have a 2002 Yukon XL and the subwoofer is blown. How do you remove the trim panels to access the speaker and is the amp intergrated into the radio or separate? Also does it have to be a factory...
Well, see your issue will be taking the trim out. The most of it has brackets that snap together and the amp that powers that subwoofer is very small. it will also be a single voice coil subwoofer and either an 8 or a 10. Need to find a very small rms subwoofer like a kicker comp. also a shallow enough subwoofer to fit in the space. the lower the rms of the new sub the more likely it will be shallower. you're probly gonna be wanting to look for a sub that is like 150 rms and no more to be powered adequately.
Top M&K Sound Mp Series Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a M&K Sound Mp Series Audio Player and Recorder Expert? Answer questions, earn points and help others
