You need to replace your color wheel. This is a very sensitive part and you need to take care when replacing. If you feel comfortable I can walk you through it. If not, I would take it to a authorized service center.
Thank youb for your advice, I do feel comfortable enough to tackle myself, however, I am not getting any audible signal that the color wheel is bad. What leads you to believe that it is the color wheel?
Thank you for your timely response.
Because your lamp is good and your ballast is good and all 3 leds are blinking. This is the common problem with that chassi these days. Your wheel is good enough to get the set started, but cannot keep a good RPM so the set is shutting down. You might be able to notice on you picture if it is bad enough. Before it shuts down look close at the display. You might be able to see the colors shifting a little bit.
