20 Most Recent Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Questions & Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. .
Samsung HLN4365W... | Answered on May 25, 2017
You need to Pull Lamp out and Look inside at Color Wheel ,Make sure it is OK and not the Same Problem.If it is OK,Then Look at Ballast Board see if it is Arking if so replace the Lamp.
Encompass Parts Distribution 1-800-638-3328
Mats Electronics has Lamps $99.00 1-800-628-1118
Samsung HLN4365W... | Answered on Mar 23, 2015
This is most probably a faulty DMD chip, because of the snowy effect, if it only happens for some seconds then it might need replacing. Normally this does not go away, have you had any repairs done to this TV recently?
Samsung HLN4365W... | Answered on Feb 06, 2014
Tip
Free help
Don't bother asking for the free assistance. It does not exist. <br /> <br /> Pay up or get nothing.
on Feb 01, 2014 | Samsung HLN4365W 43" Rear...
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
Samsung HLN4365W... | Answered on May 11, 2013
No picture on a DLP when you can see the lamp is working is ALWAYS the DLP chip. BECAUSE you recently replaced the color wheel, i suspect that the LVDS/data cable to the light engine was not plugged in well and has come loose. I suggest checking and rechecking every cable and plug you can find.
Samsung HLN4365W... | Answered on Aug 13, 2012
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
The noise could be one of the cooling fans has some debris in it or the most likely cause is the color wheel is starting to fail and will have to be replaced. If the picture starts to have color or picture problems then it is the color wheel.
Samsung HLN4365W... | Answered on Jul 13, 2011
Well that humming sound is indeed the color wheel.
Samsung HLN4365W... | Answered on Jun 08, 2011
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
Samsung HLN4365W... | Answered on Jan 31, 2011
check your colorwheel
What do the lines look like? Are they colored lines or just plain white lines?
Samsung HLN4365W... | Answered on Nov 22, 2010
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
Popular Tags
70 questions posted
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
replaced color wheel in samsung hln4365
  • Televison & Video
